Fast 102, nw 102, NX
Old Jan 16, 2018 | 04:04 PM
thatguy662's Avatar
thatguy662
Default Fast 102, nw 102, NX
Getting ready for better weather and hoping to have it tuned and spraying before tx2k this year. I would like some input on what else I need to complete my setup. New mods for 2003 z06:
fast 102 with fast fuel rails
nw 102 throttle body
nx 102mm plate kit with purge lines
lingenfelter lnc-2000 timing retard/launch control
nitrous switch panel
innovate psn-1 gauge (all in one unit - window switch, air fuel gauge, nitrous pressure gauge, shift light)
*need fuel pressure safety switch*
*need solenoid brackets - not sure which ones to get for a clean look*
*possible bottle heater*
*read issues on fitment with stock hood or pulley? Can someone confirm if I need that katech tensioner pulley or whatever it is*
*do I need injectors? Which ones? Bosch 42lb?
*do I need a new fuel pump?*
*not looking to spray alot right now so I will not be doing a standalone fuel system*
***car currently has***
-btr stage 4 cam setup
-AR longtubes
-b&b exhaust
-vararam intake
-melling oil pump
-elite catch can
-built tranzilla trans with short throw (not sure of interals but I will address if an issue arises obviously)
-m/t streets for hooking
sorry so many questions I want to do this right!! Thanks
Old Jan 16, 2018 | 04:09 PM
thatguy662's Avatar
thatguy662
Some pics of the car and setup awaiting
Old Jan 16, 2018 | 04:34 PM
banker099's Avatar
banker099
Cruising
Awesome ride! Hope to see you at TX2K! Good luck on the 102mm install i put a FAST 92mm on mine due to clearance reasons on the rear cowl.
Old Jan 16, 2018 | 06:00 PM
knewblewkorvette's Avatar
knewblewkorvette
Nice looking Vette and
Old Jan 16, 2018 | 07:19 PM
I’m going to move this over to the C5 Tech section for some answers to your question.
To Fast 102, nw 102, NX
