How I corrected rattle on left door window
Here is how I fixed it :
First I loosen the bezel around the door open carefully with a screwdriver .There is two placed to enter on the bezel and the bend the screwdirver carefully to pop off the bezel.
Then I pop off this little cover And unscrewed two T30 Torx screws
Then I used a screwdriver carefully to pop off the indoor panel , loosen all of the plastic pin locks , Lifted the indoor cover up and disconnected the plug to the door/window buttons
The mounting plastic on the indoorcover broke off , but I glued it back on with my favorite glue Loctite 3090
I the removed the plug to the doorspeaker and removed the speaker from the door
On the lower mounting point I noticed a big slack when I tried to move the window in an out .
I also noticed the rubber cylinder on top the pin sticking up.
And all the slack was gone when I tried to move the window sideways.
I the mounted the speaker and connected the speaker plug.
Held the indoor panel in a vertical position and connected the plug for the window/mirror buttons .
It is important to position these pins before pressing the indoorpanel onto the door frame to avoid cracking more of this old plastic .
When the doorpanel was proper entered on the door frame , I put the two T30 torx below the armrest back in place including the little cover
Finally I pressed the bezel around the dooropener back in place .
I hope this could help other with the same problem
Greatings form Norway
