So i have a guy willing to sell me his 799 heads from his 2007 tahoe if i remove them so i was wondering if i could also use the rockers, valve springs, valve, or any other parts from the tahoe and swap them into my c5. What can i salvage for the swap? My plans right now are the heads, then later some long tubes, a stall, then 3.42 gears, and a mild cam. I.know i will have to get center bolt valve covers since i have a 1998 c5 and coil brackets. Will the tahoe valve covers work on my ls1 or are they too tall or maybe they don't have the necessar pcv connections? Please enlighten me
It's your car, but there is not enough to gain by switching from 241 castings to 799 castings in my opinion. I also wouldn't put used springs in either, rockers could be inspected and reused but not worth the labor and parts expense. Good luck and enjoy
The latest issue of 'Chevy High Performance' magazine has an article on some of the various heads (GM) that are available for use on the LS series of engines. It might be worth a look.....
I've been reading that the 799 heads are identical to the 243 heads which were on the zo6 c5s (only different valves, zo6 had sodium lightweight valves) and supposedly provide a decent hp gain. Im able to get the heads for a great price since they are readily available on 5.3l trucks.. so other than my labor, if it is truly identical, then it won't be much $ out of pocket.
You could purchase the heads, but delay the install until you have your mild cam and springs.
i think that's a good suggestion. probably grab the heads and build them up on the side with new springs and maybe mill it a little and hold off the install till i get the cam.
Plan on a dyno tuning session to get the new combo dialed in correctly as well once you have the new parts installed.
You can mill the 799 heads .020" and you'll see decent gains.
You can reuse your current rockers, pushrods, springs if you want, although the springs in the 799 heads will likely be fine.
Get the Tahoe valve covers. The ONLY differences in the car and truck center bolt valve covers were some minor PCV differences, which you can probably figure out on your own without any trouble (assuming it even has different PCV connections).
Only difference between the 799 and 243 heads is the process in manufacturing. The 799 heads were formed in a sand process so the ports can be a bit rough compared to the 243 heads. If porting its a non-issue. Otherwise, everything is the same. Can use the other pieces.
I believe your plan sounds good overall.
You are correct about the 799 heads being virtually identical to the LS6 heads minus the lightweight and sodium filled exhaust valves.
Unless the mileage is really low I would encourage your changing springs; especially if you're going to change the cam. Long tubes, higher stall converter and 3.42 rear are good moves, too.
I would also encourage you to wait and do all the engine changes at one time so that you only have to pull the steering rack, timing cover, etc, one time. A new timing chain would be a wise move. Also you should consider a replacement harmonic balancer, too.
Let the cam you select determine what replacement springs you should use. The Tahoe rockers should be good and I understand the newer rockers have a stronger trunnion set up.
Doing everything together will allow you to go with one dyno tuning which, again, will save money. Of course you'll need another dyno tuning when you make the 3.42, and TC change, so again trying to wait and do everything at one time saves $$.
Best wishes with your project. Let us know how it goes.
yea i hear ya, the more i think about approaching these upgrades the more i am thinking that it'll be best to get everything and do the install pretty much in one phase rather than take things off, put things on, tune, then later do another phase of removing the same things again to put something else on. Not to mention getting the tune in between different phases. this is going to test my patience...nytime i get new parts i wanna put them on and drive!
