Check engine light
Old Jan 24, 2018 | 03:23 PM
claf's Avatar
claf
Default Check engine light
On my '04 conv I have the check engine light on. Only ONE CODE shows up. It tells me the Lower left, front temp sensor is the problem. Does anyone know where this sensor is and how difficult is it to change ? Car runs fine so I am not worried about driving it but I have to have it fixed before my next annual inspection (March). Thanks, Bob
Old Jan 24, 2018 | 03:33 PM
twokbolt's Avatar
twokbolt
Can you give us the exact code? It almost sounds like you are describing a tire pressure sensor but it's not clear from your post.
Old Jan 24, 2018 | 08:52 PM
claf's Avatar
claf
P0155 is the code.
Old Jan 24, 2018 | 09:57 PM
claf's Avatar
claf
Back to the original question. Is this sensor in the exhaust pipe or ???
How difficult to change and when I go to the parts department what do I ask for ???
Old Jan 25, 2018 | 03:00 PM
twokbolt's Avatar
twokbolt
Bank 2, sensor 1 would be the passenger side, front of the car. The sensor is screwed in to the exhaust similar to the way a spark plug goes in an engine head. It is doable with hand tools and a way to raise your car up high enough off the ground to get under there and access it. If you do take it to a shop it should be no more than 1 hour of labor at most.
Old Jan 25, 2018 | 03:14 PM
oelarse's Avatar
oelarse
Here is a photo of the sensor on the passenger side .
I replaced both sensor last year and installed new type AFS 75 from AC delco
(left one)
To Check engine light
