Dorman 90 intake?
Old Jan 25, 2018 | 12:07 PM
ChrisLSx's Avatar
ChrisLSx
Default Dorman 90 intake?
I'm considering converting to the Dorman 90mm intake (currently have a stock LS6) as I'm not interested in paying $875 for a FAST 92 (that's ridiculous). The Dorman 90 seems to be getting good reviews, but I wanted to get some 1st hand feedback from anyone who might actually have it.
I already have the LS2 90mm TB in hand, so all I need is the intake to make the swap.
Old Jan 27, 2018 | 07:53 AM
Booger789's Avatar
Booger789
I have been going back and forth over this for the last month. I have seen the results of the fast 92 being put on an ls6 motor. But have not seen results for the dorman. That I would deem reliable. I believe I am going to pony up and by the fast manifold and sell my ls6 intake then the hit to my wallet will not be as bad.
I to have ls2 silver blade in hand. With Texas speed 224r cam
Old Jan 27, 2018 | 09:00 AM
DetroitPlac's Avatar
DetroitPlac
What are your plans overall? Cam, heads, etc?
My car with BTR Stage 2 cam, Livernois Stage 3 243's and bone stock LS6 intake made 440 whp. A larger intake would just give me more up top, which I don't really want/need.
Old Jan 27, 2018 | 11:12 AM
ChrisLSx's Avatar
ChrisLSx
Near term plans are Kooks 1-7/8 LTs and offroad X, ported 243 heads, a cam (have not narrowed down the cam yet but something in the 22x-230 range).
Old Jan 27, 2018 | 11:52 AM
99blkfrc99's Avatar
99blkfrc99
LS6 will probably be fine. I've done a lot of research on this also. I ended up buying one for my car. I have a couple threads on dynos, install and what not. Really depends on your end goal and powerband you want.
Old Jan 27, 2018 | 12:01 PM
DetroitPlac
This.
With what you're talking about, the power band is going to be a bit high. Intake will just make it more so. Might be worth 20hp at most.
I suppose if you already have the TB and everything apart, it doesn't hurt as a "while you're there" update, but I don't think it's going to make a monumental difference.
Old Jan 30, 2018 | 10:53 AM
FASTFATBOY's Avatar
FASTFATBOY
Originally Posted by DetroitPlac
This.
Intake manifold does not dictate the power band, the camshaft does
Old Jan 30, 2018 | 11:27 AM
DetroitPlac
Correct. But the intake is just going to amplify what the camshaft does, so if you're talking about a bigger high power band camshaft, the intake is just going to make the top end power even stronger.
So it's important to consider the entire package is the point.
Old Jan 30, 2018 | 02:46 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Agreed, the entire package is a system, runner length on the intake and primary length and side on the header will influence the power curve.
Old Jan 31, 2018 | 02:16 PM
Whatsa347's Avatar
Whatsa347
A FAST 90/92 would gain everywhere over your LS6, not just up top. A FAST 102 would gain even more at any RPM over the 90/92.
Old Jan 31, 2018 | 03:05 PM
DetroitPlac
I'd love to see the a to b dyno charts.
Old Jan 31, 2018 | 04:54 PM
Whatsa347's Avatar
Whatsa347
http://www.ls1gto.com/forums/showthread.php?t=289456
http://www.onallcylinders.com/2014/1...ake-dyno-test/
https://www.google.com/search?q=fast...AZJGU0V_0S2TM:
https://www.corvetteforum.com/forums...-s-t-92-a.html
http://www.hotrod.com/articles/20-ls...ifolds-tested/
It's a superior design in every way, shape and form. LS6 isn't bad, but it's just not nearly as good as a FAST, it only get's better with porting as well. The Dorman LS2 is better than an LS6 as well, since it's a FAST lower with better runners, with minor porting it's shown to be basically a FAST 90.
Old Jan 31, 2018 | 05:07 PM
ChrisLSx's Avatar
ChrisLSx
Suggestions on who to use for porting on the Dorman 90?
Old Jan 31, 2018 | 05:29 PM
Whatsa347's Avatar
Whatsa347
WS6store does it, contact them, super helpful people over there.
Old Feb 1, 2018 | 11:01 AM
DetroitPlac
Thanks for proving my point.
The definition of "all over the rev band" is interesting to me. All these dyno charts show noticeable gains starting around 4k RPM and up...just as I said they would. The larger intake means more air volume, which really isn't realized until velocity picks up in higher RPMs.
I don't wind my car out at every stop light, so power 4k+ while awesome, is less useful than more torque between 2k and 4k. An intake won't do that, and this proves it. Just pointing out that "all over the rev band" is somewhat subjective based on driving style. Dyno charts are great, but you spend a lot of time under 4k RPM on the street. This is where forum BS doesn't necessarily translate to the street. If you're racing, an intake is absolutely a good idea.
Not at all debating the merit of these intakes...they certainly flow more and are better designed to take advantage of 4k+ RPM performance. If that's what you're looking for, then right on.
Old Jan 1, 2026 | 10:27 AM
Nosferatu333's Avatar
Nosferatu333
Did you ever put the fast on?
To Dorman 90 intake?
