C6 shifter in C5
Old Jan 25, 2018 | 06:52 PM
jeffwest5599's Avatar
jeffwest5599
Default C6 shifter in C5
Searched the forum and could not find the answer specifically. Will a manual shifter from a c6 bolt directly into a c5 without any modifications. Looking to do the change and wanted to verify. I thought it did but wanted to verify.
Old Jan 25, 2018 | 07:03 PM
candyredwing's Avatar
candyredwing
Yes, very easy, did it myself in a little over 1 hour (including the time to remove the radio bezel for access to the lower box).
Old Jan 25, 2018 | 07:08 PM
jeffwest5599
Default C6 shifter in c5
Was it a direct fit. Just remove the old shifter and put in the C6. I have removed the shifter before and it is easy. Just wanted to see if the c6 just replaces it with no modification. Thanks.
Old Jan 26, 2018 | 10:48 AM
bravo29's Avatar
bravo29
Yes direct fit. If you are not replacing the boot you will have to modify the boot end to fit over the shift ****.
To C6 shifter in C5
