I have 99 C5 have multiple codes. What is that code referring to?
A: 38 RTD(real time dampng) no communication
B: AO-LDCM(left door control Module) code U1064H
C:A1-RDCM(right door control Module) 2 codes: B2265H-Mirror verticle position sensor fault
code: U1064H
D: BO-RFA (remote function actuation) 2 Codes: U1096H -normal software function history status upon ignition cycling
U1064H-normal software function, history status upon ignition cycling
code: U1064H
Start the engine and read the DTCs with the engine RUNNING. With the engine RUNNING, CLEAR ALL the DTCs. See if any of them return.
Post up the status.
Turn the engine OFF. Restart and recheck the DTCs.
