a little back ground on my vett. 2002 6speed torch red with 2004. Engine/harness and pcm with green and blue pcm connecters. Myvett was stolen and recoverd minus engine and basicly everything they could unbolt or cut so its been a long road to get her to this point trouble shooting just about everything and im down to service traction control,a fuel gauge issue (it sat with empty tank for a year) no speedo reading on dash or hud and and a map senser issue:
so iv replaced my map senser and at first the new map was reading (i have a scan tool).and the engine ran great for 5 min Then ithe map stopped working again so i pulled the intake again and fitted another new map and still not working. The maf is operational. I have 5v at map plug connector , does anyone know where the orange/ black ground goes to ? I dont have a fsm:
i can see that grn connecter pin 32 lt green is map signal
Im a little lost
Thanks and any input would help
Reason: Missing info
