C5Z Faint Chirping Sound
Old Feb 3, 2018 | 11:40 AM
Tninl02Z's Avatar
Tninl02Z
Default C5Z Faint Chirping Sound
Hey guys i recently noticed a real faint chirping sound coming from my engine and am stumped on what it could be. I already pulled both belts and the sound is still there. The car holds good oil pressure and i recently replaced the yellow valve springs out for blue ones . I pulled the valve covers again after replacing the springs and everything looks good, re-torqued the rocker arms they were all good as well.
Here is a link to the youtube video with the sound.
https://www.youtube.com/watch?v=4k12...ature=youtu.be
Old Feb 3, 2018 | 11:59 AM
grantv's Avatar
grantv
Sorry, it chirps with belts off? Check the HB. Any wobble at all?
Edit; make a stethoscope of some sort, ear one end and listen around carefully. I found a wrapping paper tube that works for me.
Old Feb 3, 2018 | 12:03 PM
Tninl02Z's Avatar
Tninl02Z
Yes still chirps with the belts off. The balancer was recently replaced as well no wobble there. The sound seems to persist even when the car is up to temp.
Old Feb 3, 2018 | 03:06 PM
Joepro95's Avatar
Joepro95
MY ls1 has a faint chirp, it its worse when the revs fall from about 2000 to idle, if i am sitting and open the drivers door, I can hear it as the engine goes back to idle and you can hear it echo off walls and such...also with the belts off and not HB wobble...been doing it for a while now, can here it much better from under the car. Im just waiting for whatever it is to break at this point, been chasing it for along time, has not gotten any better or worse in two years. you figure it out, let me know, hopefully its the same thing.
Old Feb 3, 2018 | 07:12 PM
FASTFATBOY's Avatar
FASTFATBOY
Fans
Old Feb 3, 2018 | 07:27 PM
Tninl02Z's Avatar
Tninl02Z
It does sound like the fans but makes the noise with out the fans running. Thanks for the replies everyone. I am going to continue to drive it and dig deeper if it gets worse.
Old Feb 3, 2018 | 07:28 PM
Ed Ramberger's Avatar
Ed Ramberger
Electric A.I.R. pump?
Old Feb 8, 2018 | 10:54 PM
Tninl02Z's Avatar
Tninl02Z
Any other ideas? I am starting to lean towards a bad lifter but don't want to pull the heads just yet.
Old Feb 9, 2018 | 07:51 AM
vettenuts's Avatar
vettenuts
I don't think it sounds like lifters, the sound is too "constant" with engine rotation. Is it louder from under the car, like near the clutch and torque tube?
Old Feb 9, 2018 | 09:03 AM
Millenium Z06's Avatar
Millenium Z06
Moderator
Balancer. I had a brand new one chirp; I left it till it started to wobble which was about 500 miles
Old Feb 9, 2018 | 10:00 AM
Ed Ramberger
That was my initial thought but he said he checked it. I'm interested to see where this goes.
Old Feb 9, 2018 | 10:16 AM
Tninl02Z's Avatar
Tninl02Z
Balancer noises tend to go away once the car has warmed up correct? This noise persists when the car is hot and cold. It is only noticeable when the hood is up. I closed the hood and listened under the car and could not hear it. It sounds like it is coming from the top of the motor but still hard to tell. I noticed one of the gaskets on the intake manifold seems to be pinched, i am wondering if that could be the culprit. I think at this point i need to pick up an automotive stethoscope.
Old Feb 9, 2018 | 07:38 PM
Herbert2002's Avatar
Herbert2002
8th Gear
Changed all my pullies had squeak. No more noise.
Old Feb 10, 2018 | 03:58 AM
Swoop Dogg's Avatar
Swoop Dogg
I have a chirping sound, but mine is only at startup and sounds like it’s coming from behind the glovebox. After a minute it goes away. It’s the oddest thing.
Old Feb 10, 2018 | 08:59 AM
helga203's Avatar
helga203
He removed all the belts and it still makes the noise. Or does the crank pulley will chirp even without belts??
Old Feb 10, 2018 | 02:45 PM
Millenium Z06
Moderator
If you removed all the belts and you still have the noise, that even further points to the balancer. There's nothing in an engine that will chirp aside from the balancer.
Are you sure its a chirp/squeak that you're hearing?
Old Feb 10, 2018 | 02:46 PM
Millenium Z06
Moderator
Some do, some dont
To C5Z Faint Chirping Sound
