BCM Question
Old Feb 5, 2018 | 07:13 PM
tentuna's Avatar
tentuna
Default BCM Question
I posted a few questions on this subject since I'm working on the install for a keyless entry, ignition and have another question.
The BCM needs a ground sense for Key In and Key Out. Will a transistor switch pulled to ground for Key In be ok
If you let the Key Out floats and not pulled to ground will the BCM go into sleep mode or are there other ramifications I'm not aware of.
