Can't unscrew spark plug...
Old Oct 13, 2002 | 11:40 PM
NJVetteGuy's Avatar
NJVetteGuy
Default Re: Can't unscrew spark plug... (jreed99)
Try a straight, non-swivel spark plug socket w/ a 2" extension and a flex-head ratchet. :yesnod:
Old Oct 14, 2002 | 12:34 AM
TorchRed99Coupe's Avatar
TorchRed99Coupe
Default Re: Can't unscrew spark plug... (Patman36)
I would express some caution from proceeding with a breaker bar to remove the spark plugs. If you stripped out a spark plug hole in the heads, what are the consequences? Is it worth the savings? In my production wholesale nursery we do a lot of routine repair work on a variety of equipment. We sometimes run into situations like this. My suggestion is it is sometimes wiser to take it to a professional since a stripped plug hole will cost a lot more than the savings from doing it yourself. Having been down that road before (and the bill to fix it right!), just my two cents.
Old Oct 14, 2002 | 02:17 AM
lost's Avatar
lost
Default Re: Can't unscrew spark plug... (TorchRed99Coupe)
I have found that a few light taps on the rachet handle with a rubber hammer works wonders.....
