Oil pressure regulator
Thanks in advance.
You normally just use 6.0 qts but if you want to play hard, you can add .3-.5 additional oil. If you a HPDE, just add the extra 1/2 qt of oil that is allowed.
SO, I don't think you will have any oil starvation issues with a LS engine..
The oil pump has its own internal oil pressure regulator inside the pump which is mounted on the front of the crank .
There are improvements that you can make to the head oil drain back holes that will help get the valve train oil back into the pan better and not collect in the heads. .
Bill
- Overfill the sump by 1/2 quart to 1 quart at the track
- Make sure you have a good oil pressure gauge with a low pressure alarm, so that you can back off before damaging the engine if you see a drop in oil pressure.
- If you have the two-piece batwing pan, you can install our trap door kit, which helps keep oil around the pickup tube and prevent oil starvation: http://www.improvedracing.com/oil-pa...pan-p-743.html
- Install our crank scraper, which helps reduce oil starvation and adds 5-10 WHP: http://www.improvedracing.com/crank-...per-p-649.html
- Install a pickup tube clamp to make sure the pickup tube O-ring is sealed securely and stays in place: http://www.improvedracing.com/oil-pu...amp-p-642.html
- Add an oil cooler kit to make sure oil temps are not too high. If oil temps are too high, the oil loses viscosity and does not lubricate well enough. An oil cooler is needed for track use.
- After doing the above, if you still see oil pressure drops while cornering, you can always add an oil accumulator.
- There are a few little things you can do to help accelerate oil drain back, such as drilling the lifter trays.
- The final and best option but many magnitudes more costly is of course to switch to a dry sump setup.
Here are a few videos I made while building my car. Sometimes it helps you have a visual. I won't post it here, but I also did a video on adding an oil cooler (in my YT channel). If you get serious about HPDE, then you'll likely want one.
Here's the I.R. oil pan baffles.
Here is the I.R. oil pick up tube brace. (skip ahead to the 2min mark)
And if you ever have the upper oil pan removed from the vehicle, I used a dremel to clean up the rough casting on the oil drain holes from the upper pan to the lower pan. Probably doesn't make a huge difference but the casting holes were so rough I just couldn't leave them. But it throws aluminum shavings everywhere, so you would only do it if the pan was off so you could clean it thoroughly afterwards.
Pull the radiator and clean the outer fins to keep it cool.
No reason to spin the guts out of the engine, shift it at 6k rpm's.
Oil accumulator will help for sure.
Here I am, no issues.
