module smoking
Old Feb 14, 2018 | 08:55 AM
cgwright's Avatar
cgwright
Cruising
Default module smoking
98 c5, borla exhaust and freeflow air filter.
got into car after work and service soon,abs and traction lights came on. working fine earlier that day. pulled to side to ck under hood and a cylinder shaped module behind the radiator was spewing smoke. car was off. strong electrical smell. finally stopped smoking. started car and drove 15 miles home. car runs fine but traction and abs lights still on as well as service soon. what was the part that burned up and what caused this. thx Clayton
Old Feb 14, 2018 | 09:31 AM
runner140*'s Avatar
runner140*
Hey Clayton, after three years of membership I'm going to answer your question with a suggestion, pull your codes and report back to us what they are.
Old Feb 14, 2018 | 10:48 AM
cgwright's Avatar
cgwright
Cruising
cleared codes when this happened hoping they would clear lights. pcm p1571 hc, p1644 hc, tcs no comm are all that is showing now.
Old Feb 14, 2018 | 11:33 AM
Moved to C5 Tech.
Old Feb 14, 2018 | 12:37 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Having a difficult time envisioning what you described as what was smoking.. Was it the EBTCM????
ETBTCM: Left (drivers) side of the car directly behind the radiator and in front of the engine?
The only other electrical stuff behind the radiator are the FANs and the actual throttle body.
Any chance of a picture of the component??
BC
Old Feb 14, 2018 | 03:41 PM
cgwright's Avatar
cgwright
Cruising
yes that is what it was (ETBCM)
Old Feb 14, 2018 | 06:47 PM
SG Lou's Avatar
SG Lou
First i ever heard of a EBCM burning up
Old Feb 14, 2018 | 10:41 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Most likely has water inside the module. Remove the SIX torx screws and the two connectors and remove the electrical portion of the module..
Look for water,corrosion, moisture..
What year C5?
If 2001+ you can easily get a good used replacement.. Call VETTENUTS Recycling!!
MAKE SURE that you pry the module STRAIGHT off the BPMV to prevent breking the module coils:
BC
Old Feb 15, 2018 | 08:47 AM
cgwright's Avatar
cgwright
Cruising
thx Bill for the info. unfortunatly the car is a 98. any chance of parts being available?
Old Feb 15, 2018 | 11:10 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
New parts NO!!!
Used Parts YES!!
COST $$$$$$$$$$$$$$$$$$$$$$$$$ A LOT!!
Your best bet is to separate the EBTCM from the BPMV and see what is having issues. Maybe its something that can be fixed. Maybe not.
Bill
Old Feb 15, 2018 | 12:26 PM
cgwright's Avatar
cgwright
Cruising
thx Bill. The pics will also help. Vettenuts showed one for @ a grand! will update when i get it apart.
To module smoking
