What block do i have?
how can I prove what it has? Because it sure would be nice to know.
I sure don't doubt its true, as I have no paperwork, just word of mouth. But I am told this is what it all has.
Z06
Build List
Diamond Pistons (coated)
Callies Compstar Crank
Callies Compstar Rods
ACL coated main, rod, & cam bearings
Melling Oil pump
Double row timing set
ARP Main Studs
ARP head bolts
ARP Crank bolt
CNC Ported heads/stainless valves/TEA dual springs
Comp Cam 230/242 114
Comp Hardened pushrods
Yella Terra rockers
New GM lifters
A&A Corvettes Supercharger Kit
Vortech V-3 Supercharger (3.4" pulley) (12.2 psi @ 6800 rpm)
A&A Corvette 1000 hp Fuel System
LG long tube headers/x-pipe
Magnaflow Quad tip axle-back
NGK TR7ix Iridium spark plugs
Norris Motorsports Catch Can
MSD plug wires
Line-bored & typical checking/machining of everything needed
Lingenfelter short block
McLeod Twin Disk Clutch
McLeod Adjustable Master Cylinder
Remote bleeder
RPM Level 5 Transmission
MGW Shifter
Hardened Differential Shafts
Dewitt's SC radiator & matching fan shroud assembly
Hinson Racing urethane motor mounts
New A/C condenser
New A/C compressor
Line-lock
Pillar mount Boost Gauge
Pillar mount Fuel Pressure Gauge
HID low beams
a wild guess based of that cam spec, i'll guess it's a 5.7
If you ever see ads for people selling 98-01 LS1 camaros and Trans ams, they all put in their ads that the car had a "vette" motor in them even though anyone who knows its because it shared the same engine.
Lngenfelter will put a stamp that says LPE-(whatever deignation the engine is) on the block and heads. if you dont see a stamp that starts with LPE, it is not one of their builds.
