LS2 402 swap - won't start
Old Feb 18, 2018 | 09:40 PM
mowpow's Avatar
mowpow
Default LS2 402 swap - won't start
Hellp-
I'm doing a LS2 402 swap in my 98 A4 and finally finished it up tonight but it won't start. Here's what I checked so far:
- It sat for a bit so I pumped out old fuel and put in new fuel
- Fuel pressure at the rails shows 50 psi
- Spark is happening
- TB is opening fine
Cranking sounds a bit weird to me. It's not the typical loping sound but rather a smooth, consistent sound.
If I let it crank for a bit, I get maybe one mid-severe backfire.
I'm starting to wonder if I put the cam in wrong. I triple checked the cam when I installed it but maybe I missed something?
Been working on this for a while so I could use some guidance on this one. Definitely bummed out Thanks folks for any help in advance.
Jake
Old Feb 18, 2018 | 10:02 PM
StingrayRebel's Avatar
StingrayRebel
did you do a cam swap only and it was running before or is it a new motor?... is it throwing any codes?... if not maybe try a compression test and see if you have any dead or low cylinders
Old Feb 18, 2018 | 10:10 PM
mowpow's Avatar
mowpow
Brand new motor and cam. I need to check for codes again, when I checked it didn't show any codes but the DIC was showing low coolant, low brake fluid, service traction control, etc which I would figure would show some codes!
Compression test is a good idea, I will do that as well.
Old Feb 18, 2018 | 10:26 PM
Silverwolf_pup's Avatar
Silverwolf_pup
Hope you get it running soon
Old Feb 19, 2018 | 11:13 AM
nsogiba's Avatar
nsogiba
Cam and crank sensors plugged in?
Old Feb 19, 2018 | 03:59 PM
Deputy_Dangle's Avatar
Deputy_Dangle
I had a similar issue when I LS3 swapped my 97. I used a caspers cam sensor adapter harness which was pinned Incorrectly.
I repinned the connector and it fired right up.
Old Feb 25, 2018 | 10:59 AM
mowpow's Avatar
mowpow
Just did a compression test on cyl 1 and 4, zero
So I guess I installed the cam 180 out huh?
Old Feb 25, 2018 | 06:36 PM
mowpow's Avatar
mowpow
It's alive!!! Did some research and found some posts in another forum about valves being stuck open. So I opened the valve covers and loosened the rocket bolts a bit and got compression!! Did the same all the way around and got good compression on each cylinder. Bolted everything back up and it started right up! Thanks for the tip to check compression that's what led me in the right direction.
Old Feb 25, 2018 | 08:32 PM
frodo84's Avatar
frodo84
Uneducated autodidact
So....pushrods too long?
Old Feb 26, 2018 | 12:58 AM
mowpow's Avatar
mowpow
Hmm I hadn't thought about that possibilty. I know when I measured them using an adjustable one it seemed to measure out ok. The rockers seemed to be very tight so I am wondering if my torque wrench was off when I tightened then down.
Old Feb 26, 2018 | 10:11 AM
helga203's Avatar
helga203
Do you have adjustable rockers? Stock rockers are non adjustable?? Crank to 22ft lbs and done
Old Feb 26, 2018 | 03:55 PM
frodo84's Avatar
frodo84
Kinda got me thinking....
Old Mar 3, 2018 | 07:08 PM
mowpow's Avatar
mowpow
Hmm, I will double check them for sure. I am also getting P0343 Camshaft Position Sensor A Circuit High, is this what you were getting to Deputy_Dangle when your pinout was wrong? How did you determine the write pin out? Not sure I want to be probing around while the car is running.
Old Mar 3, 2018 | 08:55 PM
frodo84's Avatar
frodo84
What I'm saying is, if you backed off the rocker bolts and some valves closed there is an issue. LS rockers are non adjustable and supposed to fit flush, torqued down with no clearance under them. I wouldn't run the engine until you figure it out.
Old Mar 3, 2018 | 09:00 PM
StingrayRebel
he never stated if he had stock or aftermarket rockers though... on the cam harness personally I would prefer to solder in a new pigtail with the correct plug if possible, I have seen too many issues with conversion harnesses... sometimes they are pinned incorrectly and sometimes the wires are not properly crimped so you end up with a bad connection... solder/heatshrink/loom and be done with it
Old Mar 3, 2018 | 09:01 PM
frodo84's Avatar
frodo84
True. I assumed stock.
Old Mar 3, 2018 | 09:59 PM
mowpow's Avatar
mowpow
I am running Yella Terra 1.7's but they are non-adjustable so I guess that means that the pushrods are too long? Or is it still possible I torqued the rockers down too hard?
To LS2 402 swap - won't start
Old Mar 4, 2018 | 08:57 PM
C5SCCA's Avatar
C5SCCA
What are your cam specs/pushrod length? Stock or milled heads? Id venture to guess that you would strip the rocker bolt hole on the aluminum heads before you could bind the valves if your pushrods are the correct size. I would defintely check for correct length before firing it up. A quick check will give peace of mind and could save you a lot of trouble down the road. Whatever you find it is, let us know.
Old Mar 5, 2018 | 12:06 AM
mowpow's Avatar
mowpow
Cam is 242/248 112
Pushrods are 7.550"
Heads are TFS 235cc 70cc, not milled
Lifters are Lunati street hydraulic
The Yella Terra rockers came with a shim and a pedestal for each rocker. I didn't use the shim because the rub pattern on the spring was dead center. I used an adjustable pushrod checker when the engine was out.
Happy to measure again, could use some guidance on the best way to do it when the engine is in the car. I can't get to the crank bolt but can use the starter with the fuel pump relay pulled.
Thanks for all the help I really appreciate it!
Mowpow
Old Mar 5, 2018 | 08:43 AM
C5SCCA's Avatar
C5SCCA
I guess the other question I didnt ask is, how much lifter preload did you add? Im not going to pretend I know the spec for the lunati street lifter preload off the top of my head. Did you add something like .100 or .050, more or less?
I would recheck the pushrod length to be on the safe side. There's a whole host of tricks to spin the engine while in the car. From strap wrenchs to modified or pass through sockets or even spinning the alternator backwards. Removing the spark plugs will help you turn it over.
If all checks out and you're confident in you're measurement, you're good! But the not knowing part would drive me crazy. Something happened to cause the valves to stick open.
