I have a 2002 C5 base with a Dorman LS6 90mm intake manifold. I purchased a LS2 throttle body along with the LS2-LS1 throttle body adapter from Caspers. I'm throwing the Reduced Engine Power p1515 p1516 code and I was wondering, do I have the wrong throttle body? It is a LS2 TB but it has a GOLD throttle body blade. Do I have the wrong blade color? Do I need a SILVER throttle body blade?
Yes, you need the silver blade LS2 throttle body. The gold one will cause nothing but problems just like you are having. Will need some tuning also after making the swap.
I Don’t get it though. Look here’s a picture of my TB
My throttle body blade opens upwards which is what he silver blade does too. That’s the only reason for the silver blade. The only thing different is the color which idk how that would magically make everything work. So what gives?
also so I already have a full dyno tune and he said it’s either throttle body or Casper’s wire harness
