Dead instrument panel, DIC, & other issues
Old Sep 11, 2021 | 05:14 PM
Kevin7seven's Avatar
Kevin7seven
Cruising
Originally Posted by C5 Diag
MMMM ??…I was 99.9% sure the switch would have fixed it…is your mechanic a diagnostician or just a parts changer ??..see if you have any U codes present…may be a serial data bus issue…don’t know if your guy will be able to diagnose this…a lot of times we have issues with the Driver Door Module wiring…open the drivers door and shake that rubber boot on the door…see if it starts…a video is enclosed !!
https://youtu.be/f_NEEdgZSlE
I spoke to him and he told me he only cleaned it up and reinstalled it . I' have ordered the ignition switch and should arrived tomorrow and i will replace it myself . I will follow up with you before I begin .
kevin
Old Sep 11, 2021 | 05:29 PM
Kevin7seven
Cruising
I started a new thread
Old Sep 12, 2021 | 10:17 PM
Kevin7seven
Cruising
Replacing the ignition switch had it working for about 30 minutes ,then went back to the same thing again
