alignment specs?
Old Feb 28, 2018 | 02:55 PM
2k2wranglerx's Avatar
2k2wranglerx
C5 of Year Finalist (performance mods) 2019
Default alignment specs?
Hey guys,
Just bought a new vette and the insides of the tires are scrubbed. It doesn't look like camber so i'm guessing the toe is off. Anyway. While they're in there. Are you guys mostly running factory alignment specs or something else? i plan on autocrossing and running track days a few times a year.
Thanks!
Old Feb 28, 2018 | 03:13 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
This is a good guide for your starting point:
http://www.pfadtracing.com/blog/wp-c...-alignment.pdf
Old Feb 28, 2018 | 03:45 PM
2k2wranglerx
you are the man. Thanks!
Old Mar 1, 2018 | 03:23 PM
jpb1978's Avatar
jpb1978
When I bought my Z06 the inside shoulder on the front tires was completely gone, to the cords, but the rest of the tread was good. It seems the camber adjusters can move if not torqued enough, my car was at 3/8 inch total toe out in the front as a result. I now have it set to zero toe out and I check the camber cams occasionally to make sure they have not moved again.
To alignment specs?
