Upgrades to help loose handling?
How Many Miles on chassis?My 02 ZO6 is rock solid BUT, I can feel the need for improvement.
Some things to look at:
- Steering Rack: The rubber mount bushing on the passengers side of the steering rack can be changed to a POLY mount bushing. Better steering feel!!
Check the rack mounting bolts for proper torque/tightness.
- Control Arm Bushings: The bushings wear and get SOFT. Deflection is a handling killer. You can install some poly Control Arm bushings and better mounting shafts. INSPECT all of the control arm frame mounting brackets for cracks and weld failures. A known issue!
- Wheel HUB Bearing Wear. Do the wheel PUSH/PULL test on ALl four wheel HUB bearings. A good wheel bearing SHOULD NOT have any excessive slop.
My 02 Z started to have handling issues when I tried to take high speed high sweeping turns. Around 36,000 miles. If there was ANYTHING on the road (BUMPS) that upset the wheel,, the car would try to SKIDDER across the turn. A REAL BUTT PUCKER EXPIREENCE!
Changing to C6 ZO6 shocks RESOLVED that issue 100% ARE YOUR CURRENT SHOCKS STILL GOOD?ALIGNMENT, ALIGNMENT, ALIGNMENT, ALIGNMENT,. If your car is wandering down the road, your alignment could very well be suspect. Are the caster/camber adjustment eccentric bolts HOLDING YOUR ALIGNMENT?
I've seen some that were tightened but failed to stay properly aligned and slipped out of alignment WHAT alignment specs did the shop use and did they do a FOUR WHEEL ALIGNMENT? Are the settings for LEFT and RIGHT SIDE and front and rear just close to being the same or did the alignment guy try to get them nats *** on?????
Inspect EVERY strut joint, and suspension bolt for slop, looseness and or failure.
- Check your chassis TUNNEL PLATE bolts!!
90% of the cars that I have check, ALL have very loose tunnel plate fasteners! If you can install a 1/4" aluminum plate or at least get a C6 thicker plate.
Let me know what you find!
Bill
Bill
Check at least:
- Control arm bushings. Poly bushings are available for this application
- Ball joints, upper and lower. I believe that Moog "problem solver" units are available for this application.
- Stabilizer bar mounting bushings (poly bushings are availabe)
- Stabilizer bar end links.
- Tie rod ends
- Steering rack and pinion, check for excessive play. If there's excessive play, a rebuild is recommended. There is an adjustment, but usually if it's loose, there's other internal items that need to be refreshed, and seals and other "wear items" should be replaced.
- Wheel bearings (I forgot these before)
In my experience, on any vehicle, replacing all the loose/worn parts at the same time results in "like new" handling and tight, responsive steering. Replacing things piecemeal just wears out parts. Whatever the next loosest part is, that part will allow excessive movement/slop/vibration, and the movement/slop/vibration will quickly wear out the new parts.
Check at least:
- Tie rod ends
https://www.corvetteforum.com/forums...r-upgrade.html
The cars are a decade plus old so leaky shocks would not be a surprise. How long have they been on the car? I also believe it is a good idea to re torque cradle and a arms bolts.
http://www.eliteengineeringusa.com/t...que_Values.pdf
I agree with checking everything out as posted above. Poly does come with some noise down side, especially in the A arms IMO. I would go with new sway bars and hold off on a full poly conversion. DRM does sell a delrin steering rack bushing which I would do. I also think it is more likely that the car would need wheel bearings than new bushings. SKF x trackers are what the HPDE guys and racers go with. Froggy did have some a arms with the t1 bushing in them for sale which is a step between stock and full poly, don't know if they ever sold, check the autox classifieds.
Sounds like the 26 vs 23 is for the size of the sway bar.
For the tie rod ends, I'm not seeing any difference between Z06 and the other (lesser) models. On RockAuto.com, I'm only seeing AC-Delco "professional", not the original equipment grade parts, and I'm seeing Moog "Problem solver" parts as well. Generally, when I see "problem solver" line parts, they resolve some issues with the original equipment and I go with those. I haven't had a "problem solver" one yet that caused more issues than it fixed, or that didn't last at least as long as the original. YMMV.
Oh, and I didn't quote it, but the 23mm/26mm thing for poly bushings is the size of the stabilizer bar the bushings fit. You need to match the stabilizer bar you'll be using with the bushings. If you're upgrading the bar at the same time, buy the bushings to match the new, upgraded bar.
I can't believe I left wheel bearings off my list. I've gone back and added that now. You are correct that wheel bearings at 15+ years/70K miles could be an issue. Even thought both the front and rears on the C5 appear to be sealed "wheel bearing/hub units", and those tend to last a long time, I'd check them closely and replace them in axle sets if I found any issues with worn/loose wheel bearings.
Describe what the car is doing while driving down the road. Is it pulling from one side to the other as the road surface changes? If so adding a little bit of front toe in can settle down the wander. Is the car lowered? If lowered too far you can get some unusual handling on bumps if you hit the bump stops inside the shocks. Some of the Bilsteins were built to avoid that situation.
Really need alignment settings. Your friend may be a Corvette guy but is he a C5/C6 Corvette guy? Is the car aligned for street tire mileage or aligned for the track?
What tires have you been putting on the car?
Bill
