C5 HPDE build
Old Mar 7, 2018 | 05:23 PM
TomReid's Avatar
TomReid
Default C5 HPDE build
Here's a shout out to all the track rats on this forum. I'm in the process of buying a 2000 FRC that I'm going to use as a dedicated track day car. It's already got most of the performance mods done to it, but it has the stock oil pan. I know starvation is an issue for these cars under hard cornering. What are the suggestions for upgrading the oil pan to prevent this? Look forward to hearing from you!
Tom
Old Mar 7, 2018 | 05:48 PM
bigmackloud's Avatar
bigmackloud
GM recommends running an extra quart of oil when on the track.
Improved Racing sells a set of oil pan baffles for the 2pc batwing oil pan.
An accusump would be the next option. Or if you have the money, a true dry sump system is the ultimate answer.
Also check out the autocross/road race sub-forum for HPDE/track specific conversations.
Old Mar 7, 2018 | 05:52 PM
TomReid's Avatar
TomReid
Thanks for the info!
Old Mar 7, 2018 | 09:12 PM
FASTFATBOY's Avatar
FASTFATBOY
https://www.corvetteforum.com/forums...e-learned.html
Old Mar 10, 2018 | 11:42 PM
Frank O'Brien's Avatar
Frank O'Brien
If your not running slicks you'll probably (but I want to say never) have an issue. Accusump +oil cooler+improved racing trap door+high pressure oil pump =best economical choice. Run 400 tread wares for sneakers and forget the above!
Old Mar 12, 2018 | 09:09 AM
jjc508520's Avatar
jjc508520
How would you know if you were having an oil starvation issue?
Old Mar 12, 2018 | 10:00 AM
FASTFATBOY's Avatar
FASTFATBOY
He knows what's up.
I run on slicks, never had an issue with the stock LS6.....Although I do run restricted push rods to keep some oil out of the top of the engine.
If you aren't an advanced driver(read a lot of track experience) you shouldn't be on slicks for a LONG time.
Old Mar 12, 2018 | 10:02 AM
TomReid's Avatar
TomReid
You know you're starving when you going around a corner and oil pressure drops. In these engines you don't want oil pressure much below 40.
Old Mar 12, 2018 | 01:05 PM
nsogiba's Avatar
nsogiba
Oil cooler is a great idea as well.
The oil pan baffles are inexpensive and nicely built.
Old Mar 20, 2018 | 02:19 PM
NSFW's Avatar
NSFW
How likely is oil starvation with 200tw tires and no oiling mods other than a catch can? The track I'll be at (The Ridge, in WA) has a long, flat, 180-degree left.
Thanks!
P.S. This is not my first track car, just my first Corvette.
Old Mar 21, 2018 | 12:21 PM
fuggles's Avatar
fuggles
Not all 200tw tires are created equal. There is no standard for measuring. Manufacturers can make up whatever number they want.
Your situation sounds a bit scary. The tracks I go to don't have long left hand turns. I would log the pressure and watch it in the DIC. With an extra qt of oil. Wait and see or get a baffle kit and have the oil analyzed by blackstone. as precautions. only the paranoid survive.
Old Mar 21, 2018 | 06:40 PM
NSFW's Avatar
NSFW
What I mean is, do people only run into this with slicks, or are good summer tires enough to do it?
To C5 HPDE build
