Headgasket
Old Mar 9, 2018 | 05:04 PM
99redc5vette's Avatar
99redc5vette
Default Headgasket
I am in the middle of doing my cyl heads on the procharged corvette.
I believe stock gasket is .052" compressed. I want same thickness/bore size as stock. I see couple options as to headgasket choice. cosmetic. mls ect.
I have attached 2 links, pretty much same specs, I am picking up arp headbolts so I want good quality headgasket.
http://www.jegs.com/i/Cometic-Gasket...791+4294828856
http://www.jegs.com/i/Mr-Gasket/720/...791+4294828856
what y'all think?????
Old Mar 10, 2018 | 12:41 PM
99redc5vette
Anyone??
Old Mar 10, 2018 | 01:31 PM
feeder82's Avatar
feeder82
Can't go wrong with Cometic
Old Mar 10, 2018 | 03:40 PM
itsslow98's Avatar
itsslow98
Ls9 gaskets are the go to
Old Mar 10, 2018 | 04:23 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
I’d agree with this right here. ^^^
Old Mar 10, 2018 | 09:27 PM
feeder82's Avatar
feeder82
Really? that sounds like a great way to have carbon build up and hot spots in the uncovered areas between the block and heads
Old Mar 10, 2018 | 11:43 PM
99redc5vette
I have heard mixed reviews on the LS9 headgasket.
Couple .100 thou bigger bore size also. Which probably be ok but not sure would prefer tighter bore clearence.
However heard best for boost.
http://www.jegs.com/i/Chevrolet-Performance/809/12589226/10002/-1
VS
http://www.jegs.com/i/Chevrolet-Performance/809/12622033/10002/-1
Feeder you have heard bad review w the ls9???
Old Mar 11, 2018 | 08:45 AM
feeder82's Avatar
feeder82
no reviews, just doesn't make since to me to have a head gasket .10 bigger than your bore size.
Old Mar 11, 2018 | 09:49 AM
vettenuts's Avatar
vettenuts
Why not the stock GM MLS gaskets? Very forgiving. Thick with a supercharger, I would upgrade to the ARP studs.
Old Mar 11, 2018 | 11:44 AM
99redc5vette
Ya I am running 12psi give or take and see everyone loves the Ls9 for its durability to handle boost. GM MLS gasket you are reffering to the part#12589226?? I heard this gasket used in 10psi supercharged setups with no issues. I mean probably both be good but I want the best since I dont want to do this job anytime soon! Hoping some more people will give some more feedback from there personal experiences with these gaskets.
Old Mar 12, 2018 | 08:01 AM
JHrinsin's Avatar
JHrinsin
Here are the head gaskets for the LS1/6 engines. Using a head gasket for the 4.000" or larger bore engines is not truly recommended on the smaller bore LS1/6 engines;
12498543 '97-01 graphite composite gasket LS1/LS6 3.905" bore, 0.052" compressed, 10.2cc volume
12498544 '02-04 MLS head gasket LS1/LS6 3.930" bore, 0.053" compressed, 10.5cc volume
C5475-051 Cometic MLS head gasket LS1/LS6 3.910" bore, 0.051" compressed, 10.03cc volume
C5475-040 Cometic MLS head gasket LS1/LS6 3.910" bore, 0.040" compressed, 7.9cc volume
Old Mar 13, 2018 | 10:25 AM
helga203's Avatar
helga203
Default Head
I ran 23ish lbs of boost with mls gaskets for years once I started running 30lbs boost they started pissing coolant and still ran it this way gr8 a few yrs. Changed to ls9 and so far hold good.
Old Mar 13, 2018 | 04:30 PM
99redc5vette
Ok so I think I will use the MLS GM performance ones at .051". I am only at a fixed 12psi so these should be good.
Thanks everyone for replying!
To Headgasket
