Do All Corsa Exhaust Systems Leak?
Old Oct 16, 2002 | 04:25 PM
SCREAMS's Avatar
SCREAMS
Default Re: Do All Corsa Exhaust Systems Leak? (LIGHTNING)
No problems here, mine were on the car when I got it. They pop and crackle like a sumbeeatch though. No X pipe yet.
Old Oct 17, 2002 | 06:13 AM
shockwave's Avatar
shockwave
Default Re: Do All Corsa Exhaust Systems Leak? (Dick Kriss)
Mine have not moved but they do leak and I was told they all leak some. One picture is worth 10K words
That picture appears to show a flat spot similar to what one would get using a hammer to aid in the installation. If so, it would hamper the sealing of the two pipes increasing any leakage. Now I am curious, and will have to look at mind to see if I have similar leakage. I do have over 32K miles on my Corsa's...
Old Oct 17, 2002 | 07:37 PM
Arkay's Avatar
Arkay
Default Re: Do All Corsa Exhaust Systems Leak? (shockwave)
I watched the guy that installed the system and don't recall him using a hammer. I was just told they all leak some. I had the car at the dealer this week to fix he ABS failure in the left front wheel and asked them to move the clamp. I think they forgot. I will be going back for an oil change soon and will ask them to move the clamp at that time. It is too hard to do anything with hand tools - air tools are needed.
Old Oct 17, 2002 | 07:47 PM
WEF's 95's Avatar
WEF's 95
I've never heard anything but good stuff about Corsas. Mine fit perfectly and no leaks.
Old Oct 17, 2002 | 07:48 PM
Skyguy^^'s Avatar
Skyguy^^
uuh...just curious, why would need you need to use "air tools ?:confused: :cheers:
Old Oct 17, 2002 | 09:05 PM
Arkay's Avatar
Arkay
Default Re: Do All Corsa Exhaust Systems Leak? (Skyguy^^)
I tried and could not move the bolts on the clamps. The guy that did the install said he set the touque as Corsa recommended did not want to apply more in fear of twisting off the nuts.
An air wrench just makes it easier.
Old Oct 17, 2002 | 09:32 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
thats for sure. :)
vetterdstr :cheers:
Old Oct 18, 2002 | 08:22 AM
skidmarc's Avatar
skidmarc
I have changed my exhaust numerous times....Have had Corsa Touring and Pace....41k miles on my 2000 and no trouble at all....the only problem I had was that there instructions provided with exhaust had wrong torque specs...I called them and they fixed em.....I think it was for the hangers in the back...originally it called for I believe 40 lbs which was way too much for a hanger bolt....should be 17lbs I THINK its been a while!!!
I will be installing my pace on a 99 I just bought....Only thing I can recommend is using new gaskets and if necessary a rubber mallet..no hammers!!!
Marc
Old Oct 18, 2002 | 05:03 PM
Jeff Jeff's Avatar
Jeff Jeff
Default Re: Do All Corsa Exhaust Systems Leak? (skidmarc)
Mine leak at the clamps. The problem is with their "torca" clamps. I have black soot at where the clamps are located. Not sure if all of them do it, but no matter how tight I make the clamps, it doesn't help.
Old Oct 18, 2002 | 06:14 PM
Arkay's Avatar
Arkay
Default Re: Do All Corsa Exhaust Systems Leak? (Jeff Jeff)
Thanks for coming out of the closet and posting. I was getting to think I had the only set of Corsas that leaked - even after Godzilla tightend the clamps
[Modified by Dick Kriss, 4:16 PM 10/18/2002]
Old Oct 18, 2002 | 08:14 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Thanks for coming out of the closet and posting. I was getting to think I had the only set of Corsas that leaked - ....
Dick, I'm not totally convinced that yours are leaking exhaust gases. Most exhaust leaks I've ever had are black and sooty at the point of the leak.
Are you sure that isn't a water stain in that picture? ALL exhaust systems will leak mositure at any juncture.
Tom
[Modified by TCW, 7:15 PM 10/18/2002]
Old Oct 18, 2002 | 08:20 PM
LoneStarFRC's Avatar
LoneStarFRC
Same here. The system itself is tight and doesn't move, but I get a small amount of the sootiness too.
Robert
Old Oct 19, 2002 | 05:32 PM
  #33
00C5vert's Avatar
00C5vert
Default Re: Do All Corsa Exhaust Systems Leak? (BLUBYU2002C5)
BLUBYU2002C5 I would like to hear your car some day. I'm looking to get new exhaust next year and just haven't been able to hear anything as of yet. And I live in Crete, IL. I probably even have waived to you.
Thanks, Wade
Old Oct 19, 2002 | 06:51 PM
  #34
TheWoody's Avatar
TheWoody
Default Re: Do All Corsa Exhaust Systems Leak? (Tx99FRC)
Have them welded up. The torca clamps are not worth a penny.
Old Oct 19, 2002 | 07:06 PM
  #35
Maalox's Avatar
Maalox
St. Jude Donor '06-'07-'08
I have had two sets on two different vettes and also a set on my Chevy Silverado.
NO LEAKS, NO MOVEMENT
Satisfied customer
David
Old Oct 19, 2002 | 08:35 PM
  #36
2thDr's Avatar
2thDr
Default Re: Do All Corsa Exhaust Systems Leak? (Maalox)
No leaks, no movement.
They sound so good that it makes something else point up however!
Old Oct 19, 2002 | 08:54 PM
  #37
evil-1's Avatar
evil-1
Default Re: Do All Corsa Exhaust Systems Leak? (Snake Slayer)
12K miles no problems. I do have mine spot welded. :cheers:
Me too, tips pointing up is a new one on me....... :yesnod:
Old Oct 20, 2002 | 12:32 AM
  #38
newberd's Avatar
newberd
I don't have Corsa but my Tri-Flow's do the same thing. Black soot at and around all the joints. I think the problem is with torca clamps. I have tightened to point of stripping the threads and everywhere in between and no help. The right muffler give me the most trouble, can't keep it streight and level.
In the pic the soot is all over the rear carrage assembly several inches away, just like mine. That tells me its being blown there by leaking exhaust. I have thought about using the a ubolt type clamp but that make the exhaust harder to get apart come mod time. Same thing with welding.
Someone out there surely has a solution. :cheers:
Old Oct 21, 2002 | 04:38 AM
  #39
LIGHTNING's Avatar
LIGHTNING
Default Re: Do All Corsa Exhaust Systems Leak? (newberd)
rep from corsa told me if you weld, you void warranty.
