Do All Corsa Exhaust Systems Leak?
Old Oct 15, 2002 | 06:16 AM
LIGHTNING's Avatar
LIGHTNING
Default Do All Corsa Exhaust Systems Leak?
i'm getting that impression from the posts i'm reading. all the corsa's either leak or the tips start pointing upward, especially after full throttle.
Old Oct 15, 2002 | 09:56 AM
90 droptop's Avatar
90 droptop
Default Re: Do All Corsa Exhaust Systems Leak? (LIGHTNING)
Mine are fine...........
Old Oct 15, 2002 | 10:30 AM
Mark VerMurlen's Avatar
Mark VerMurlen
Mine don't leak and the tips are perfectly aligned and haven't moved.
- Mark
Old Oct 15, 2002 | 11:00 AM
Cajun99's Avatar
Cajun99
Haven't had any problems with my Corsa Touring's w/Pro Tips :cheers:
Old Oct 15, 2002 | 11:03 AM
Tormania's Avatar
Tormania
Cruise-In IV Veteran
Cruise-In V Veteran
This is the first I've ever heard of the Corsas leaking or moving. Mine are rock solid w/ no leaks.
Old Oct 15, 2002 | 12:23 PM
BLUBYU2002C5's Avatar
BLUBYU2002C5
Default Re: Do All Corsa Exhaust Systems Leak? (Tormania)
Corsa Indy-Pro's and no leaks no pointing upwards, everything is fine and I love them :cheers: :yesnod: :yesnod: :cheers: :seeya
Old Oct 15, 2002 | 12:27 PM
ddawson's Avatar
ddawson
Default Re: Do All Corsa Exhaust Systems Leak? (BLUBYU2002C5)
No problems here. The tips are still in the same spot after 6 months.
Old Oct 15, 2002 | 12:39 PM
Skyguy^^'s Avatar
Skyguy^^
No problems here :D
Old Oct 15, 2002 | 01:40 PM
shockwave's Avatar
shockwave
Default Re: Do All Corsa Exhaust Systems Leak? (Skyguy^^)
No problems here :D
Ditto....My Pro Tips still look and sound GREAT! If they move, I am not aware of it. Since they mount the same as all the others, why in the world would they move any differently anyway.
Old Oct 15, 2002 | 05:35 PM
Rob 2K1's Avatar
Rob 2K1
Mine are straight and don't leak. I've had them on for almost two years.
However, I have heard that the tips can get out of alignment from lots of wheel hop. That would happen with any aftermarket exhaust.
-Rob
Old Oct 15, 2002 | 05:36 PM
Snake Slayer's Avatar
Snake Slayer
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: Do All Corsa Exhaust Systems Leak? (Rob 2K1)
12K miles no problems. I do have mine spot welded. :cheers:
[Modified by Snake Slayer, 4:36 PM 10/15/2002]
Old Oct 15, 2002 | 06:51 PM
tito's Avatar
tito
Default Re: Do All Corsa Exhaust Systems Leak? (Snake Slayer)
3 years here with the Touring, No problems
Old Oct 15, 2002 | 07:00 PM
AFVETTE's Avatar
AFVETTE
Not sure what your talking about - Leak what water or exhaust fumes?Mine are perfect.
Tom
USAF Retired
Old Oct 15, 2002 | 08:22 PM
C5JONNY's Avatar
C5JONNY
No probs here.
Old Oct 15, 2002 | 08:25 PM
RSVETTE's Avatar
RSVETTE
No leaks here :D
I haven't seen any post about any problems. :nonod:
:cheers: :seeya :cheers:
Old Oct 15, 2002 | 09:51 PM
HOCKEY's Avatar
HOCKEY
Default Re: Do All Corsa Exhaust Systems Leak? (RSVETTE)
Mine are OK but only 100 miles on them.
Old Oct 15, 2002 | 11:38 PM
golfnwatchesnc5s's Avatar
golfnwatchesnc5s
Default Re: Do All Corsa Exhaust Systems Leak? (Cajun75)
:cheers:
To Do All Corsa Exhaust Systems Leak?
Old Oct 16, 2002 | 08:14 AM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
No leaks or alignment problems with mine after 6 months of daily driving! Also, my Corsas are bolted on, not welded.
Tom
[Modified by TCW, 7:16 AM 10/16/2002]
Old Oct 16, 2002 | 11:31 AM
Arkay's Avatar
Arkay
Mine have not moved but they do leak and I was told they all leak some. One picture is worth 10K words
Old Oct 16, 2002 | 11:37 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Mine have been good since day one. The only time they get out of alignment is when they are removed and reinstalled after Modifications.
vetterdstr :cheers:
