Convertible top adjustment
This shows your rear #5 bow adjustment, which will change the actual tension to the rear deck lid, or tonneau. You will need a 13mm and a
15mm for this adjustment. Turn in the adjustment to pull the bow away from the lid, turn out to extend the bow towards the tonneau. A gap of 2 millimeters is what you are looking for.
As a sidebar, there is a revised weatherstrip with a stuffer, that can be installed, from the 02 model year, to insure that the bow does NOT contact. 02-08-111-01 gives you the part number as 10319827.
It says a gap of 2mm is what you need. A gap where?
