Is it as simple as removing the rocker arm bolt, pulling the pushrod then reinstall and torque to correct spec? I wanted to check length and for damage because of a loud peck I have on a cold motor.
There are plenty of videos on YouTube on how to measure pushrod length. You'll need an eight inch caliper to measure accurately. Use a caliper, don't fiddle with counting the number of turns on the pushrod checker. Counting turns on the checker isn't precise. Also put a couple of turns of teflon tape on the threads of the checker tool. The tape will keep the checker halves from turning too easily and ensure accurate readings.
I have a digital caliper would something like that work? I don't know that I will try and mess with lifter preload or anything. I was just going to pull the pushrods and check them on a flat surface to see if I could visually see any bent or signs of wear. So IF this tapping I have is a lifter preload issue what would cause that considering everything in my motor is stock other than updated valve springs? All the rocker bolts are tight and there is no play in any of the rockers...
If the engine is stock, and all you're doing is checking for bent pushrods, then there is no need to measure them. If one is bent, buy a new one at a Chevrolet dealer in the stock length. A digital caliper can be used to measure, no problem. I think stock pushrods are are 7.4" long so a caliper must be 8 or more inches long to measure with. I wouldn't mix pushrods though unless a replacement is an OEM pushrod. Otherwise, all 16 should be from the same manufacturer and be the same length, diameter and construction material. Valve lash noise can come from many sources, such as low oil pressure, a collapsed lifter, worn lifters, etc.
Once you're satisfied that everything that you can inspect looks OK, make sure you have clean oil and a new oil filter before you go too much further. Some engines do make more valve train noise than others.
Reason: Fix wording.
Everthing is stock. I do have an 8" digital caliper so I will use that to check since I'm taking them out. Just changed my oil the other day, I've tried several. I used Amsoil's sig series 0w30 this time and a Wix filter with no changes, maybe slightly louder actually. As far as a lifter bleeding down that may be the case but I have checked each rocker and could not moved the pushrods down any by pushing on the rocker tip, which I thought if it was a collapsing lifter there would be some play there.. so idk. The sounds disappears after idling for a bit so I'm optimistic that the roller on the lifter is not damaged.
Bent pushrod could be possible. Keep the rocker and pushrods in order and look at the tips of the pushrods, tips of the valves, and the points they contact on the rocker looking for any that are wearing differently.
Exhaust leaks have been known to tick then go away.
Does the car have a rocker trunion upgrade? They can be a bit louder at start up especially if the car sits for a while.
Take a good look at the valve springs, LS6s have been known to break factory springs. It would not be a bad idea to replace them. They are not that expensive and relatively easy to do. If it was a spring I would think the noise would not go away.
When I first heard it I crossed my fingers it was an exhaust leak or a plug backing out but it's definately not... at least I'm about 99% sure its not... rocker trunions are stock and I had my springs replaced immediately after buying the car, I replaced the yellow springs with the updated blue set. I doesnt sound like bent pushrod videos I have watched on youtube but I guess one could be slightly bent enough to cause lifter preload issues. Maybe once it warms up and expands thats why it goes away
That was my thought on the pushrod, or a worn tip where something was not centered on reassembly or something in the oil prevented proper lubrication.
As Tbrowne said, some LS motors are just louder than others. I have noticed my LQ4 in my truck that it runs louder on Valvoline 5w30 than Mobil1 5W30 despite the Valvoline being ranked as equal if not better oil.
Remove and install with lifters on the base circle. There is a GM procedure for doing so. If stock, length isn't in question, only damage.
Good advice with the tape. I did the same but went threw hell . Get Manton pushrods. The best
