if you have a mini torch maybe you could carefully try to apply some heat to the studs to help loosen the nuts... obviously do your best to stay away from the carpet
Simple answer.....jack up the car on pucks and put it on jack stands.
Take a look....they can be replaced. I just put in new seatbelts and had to drive/drill in new anchors right next to the seat bolts. Not difficult at all.
Get as much room as you can, move the seat all the way up....put a wrench on it with a cheater/breaker to get leverage on the wrench.
Reason: add
