Check out our Performance C5 Trans/Diff Mount!
Old Mar 20, 2018 | 01:57 AM
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Default Check out our Performance C5 Trans/Diff Mount!
LUX Trans/Differential mount (LUX TDM)
Designed for the C5 Corvette, SacCityCorvette’s SuperDuty LUX TDM will stabilize the C5 Corvette Trans/Diff and help eliminate drive train shutter that feels like wheel hop. The LUX TDM has a large amount of Polyurethane to minimize noise and vibration making it comfortable for street driving yet stout and firm enough to keep the Trans/Diff stabilized during hard launches, power shifting, racing or just spirited driving. The stock rubber mount is very soft and allows a substantial amount of movement especially with any type of power adders and Drag Radials/Slicks. Keep that Trans /Diff where it belongs with the LUX TDM!
Powder Coated for protection.
Grade 8 & 10.9 Hardware for strength.
Installed with your factory 2 nuts & 2 bolts.
Made In The USA!
For more info
http://www.saccitycorvette.com/C5LUXMount.html
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old Mar 20, 2018 | 09:33 AM
vettenuts's Avatar
vettenuts
Interesting, especially since I am not sure the stock GM unit is available anymore.
Old Mar 20, 2018 | 05:23 PM
mrmagloo's Avatar
mrmagloo
Can you get it in black?
Old Mar 21, 2018 | 12:37 AM
SacCityCorvette
Supporting Vendor
Sorry, at this time they are only in Polar White. They look really nice.
Maybe the next batch we make we could do black.
Christian
Old Mar 21, 2018 | 10:26 AM
nsogiba's Avatar
nsogiba
Looks like a nice unit at an affordable price compared to the competitors.
No "wings" on the sides to prevent side to side rocking motion? Is the poly stiff enough to prevent that on its own?
Old Mar 21, 2018 | 12:38 PM
mrmagloo's Avatar
mrmagloo
How does this compare to the Hinson regarding transmitting vibration and overall strength? I know Pfaff has their version which is a whole different animal, so it would be good to get some idea on how this should perform vs the Hinson which is the closest in design.
Old Mar 21, 2018 | 02:39 PM
SacCityCorvette
Supporting Vendor
Hi nsogiba,
Yes the poly in stiff enough. Also the shaft has big grooves in it that the poly has molded around that keeps the shaft centered and from sliding side to side.
Christian
Old Oct 12, 2019 | 03:41 AM
SacCityCorvette
Supporting Vendor
Prefect for stock and high HP C5's and C5 Zo6's!
Old Apr 29, 2020 | 02:31 PM
ericba's Avatar
ericba
St. Jude Donor '21-'22-'23
Installed mine over the weekend and it eliminated the wheel hop/shudder I was experiencing during hard launches. I will warn others though that to watch for the upper brake lines that route above the transaxle. I tweaked mine enough that they would vibrate against the body tub and create a very loud and disturbing noise on launches. I thought I fixed one problem but created another! Once I tweaked the lines back, all is good.
Old Apr 30, 2020 | 02:22 PM
SacCityCorvette
Supporting Vendor
Thank you ericba for the good word and your business!
Christian
Old Apr 16, 2022 | 05:01 AM
SacCityCorvette
Supporting Vendor
Hi Everyone,
Just want to let you know that we have our LUX Transmission/Differential Mounts (TDM) in stock if you need
a performance upgrade or replacement for your flimsy stock mount.
https://www.saccitycorvette.com/C5LUXMount.html
Thank you
Christian
Old Apr 21, 2022 | 09:16 PM
SacCityCorvette
Supporting Vendor
Old Apr 22, 2022 | 10:47 AM
helga203's Avatar
helga203
Originally Posted by SacCityCorvette
Is there any side to movement or is that black stuff just vibration???
Old May 25, 2022 | 04:06 PM
SacCityCorvette
Supporting Vendor
Hi,
There is very little side movement. Less then 1/8" if any.
Thank you,
Christian
To Check out our Performance C5 Trans/Diff Mount!
