Tcm code 1243 in '99
Old Mar 22, 2018 | 08:38 PM
skittlenips's Avatar
skittlenips
Default Tcm code 1243 in '99
Hi guys today I took out vette and it was sprinkling slightly (rare sight here in Vegas). I took it around a couple corners just to get the rear end loose and have some fun. Well while doing this i activated my active handling and it throws the warning lights of service abs and service active handling. Well I pulled over and checked my code 1243 H. I didn't clear the code and started the car up again to see if it went away and it did. The warnings only come on when I end up using the active handling.
​​​Any tips on fixing this? Thanks.
Old Mar 22, 2018 | 11:39 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
not sure what you are trying to accomplish if you don't clear the code it wil always show as an H......if you don't want to get warnings turn off AH before you do crazy stuff...
Old Mar 22, 2018 | 11:41 PM
skittlenips
Whenever I do something in the car that would activate active handling, my service traction control and service abs light comes on. I pulled the codes and that was the only one there.
To Tcm code 1243 in '99
