Balancer wooble
Old Mar 23, 2018 | 12:46 AM
gpruitt54's Avatar
gpruitt54
Default Balancer wooble
After starting the car for first time since storing, I noticed that the balancer has some wooble. Am I looking at an expensive repair?
Old Mar 23, 2018 | 12:48 AM
grantv's Avatar
grantv
Any chance you can DIY?
If so, no.
Regardless get it fixed pronto.
Old Mar 23, 2018 | 12:55 AM
gpruitt54's Avatar
gpruitt54
If so, no.
I just changed out the flex brake lines with stainless steel flex lines. Does that put me in the running for doing this kind level of repair?
Old Mar 23, 2018 | 01:14 AM
gpruitt54's Avatar
gpruitt54
I just watched a video that Froggy did on replacing the balancer on his Z06. I don't think I want to tackle that job. So, I will likely pay someone to replace the balancer. It looks like an expensive job.
Old Mar 23, 2018 | 01:48 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
figure about $650-800 parts and labor...if you have any plans of changing belts hoses coolant add that to it since they will be there anyway....
Old Mar 23, 2018 | 02:38 AM
Brad Kirby's Avatar
Brad Kirby
If you want to make a trip to Indy (I live less than half an hour north of Indianapolis), we can knock that out in an afternoon. PM for details.
Old Mar 23, 2018 | 08:27 AM
runner140*'s Avatar
runner140*
Damn, what an offer. You know who, should jump on it.
Old Mar 23, 2018 | 09:19 AM
Robrote's Avatar
Robrote
That's what I'm talking about! Kudos to BK
Old Mar 23, 2018 | 10:57 AM
1997 C5's Avatar
1997 C5
Some wobble is normal on C5. Mine has wobble too. I'm just going to keep an eye on it for now. It shows no signs of failing. There's more posts here you can search on this. I talked to a guy on FB his vette has a wobble he never changed the balancer it fine to this day. Just because it has a wobble(depends on how bad the wobble is) doesn't mean it is bad or will fail. Of course always good to replace as preventive maintenance because when it does back out it will cause some damage.It's up to individual to decide whether to replace it for peace of mind.
To replace the harmonic balancer you have to remove the steering rack assy and drop the engine cradle.
Old Mar 23, 2018 | 12:36 PM
gpruitt54's Avatar
gpruitt54
It does not appear to be a lot of wooble. That is relative, I don't thing its a lot of wooble. But, this is my first Vette. So, I don't have a reference gauge.
Old Mar 23, 2018 | 12:40 PM
1997 C5's Avatar
1997 C5
I'm curious to see the wobble, can you post video? That way I can compare to mine.
Old Mar 23, 2018 | 01:22 PM
Smoken1's Avatar
Smoken1
You do not need to drop the engine cradle
Old Mar 23, 2018 | 08:38 PM
gpruitt54's Avatar
gpruitt54
Yes, I will make a video.
Old Mar 23, 2018 | 10:47 PM
StingrayRebel's Avatar
StingrayRebel
you don't have to remove the rack either, it just needs to be moved over to the passenger side and you can maneuver the outer tie rod up and out of the way of the balancer
Old Mar 24, 2018 | 12:20 PM
zone-7's Avatar
zone-7
Truth !
Old Mar 28, 2018 | 04:58 PM
gpruitt54's Avatar
gpruitt54
I took a short video of my Harmonic balancer wobble. Here it is:
How does this differ from yours? And, is this an issue for my car?
Old Mar 28, 2018 | 10:39 PM
foggy's Avatar
foggy
That's really not bad.. Just keep an eye on it.. I wouldn't panic yet..
To Balancer wooble
Old Mar 29, 2018 | 08:07 AM
96redvette's Avatar
96redvette
I noticed a slight wobble on mine last week. Mine is probably less then the video just posted. I'll be keeping an eye on it though. I ended up modifying a socket with a wrench to at least make sure the balancer bolt is tight and it was, so that was reassuring.
Old Mar 29, 2018 | 12:17 PM
Tony S45's Avatar
Tony S45
gpruitt54:
At 58.9k ,miles, my 2003 HB & tensioner wobble was quite a bit worse than yours. It didn't cause a sqeaky belt nor did the belt skip off the HB or the tensioner; however, every time I started the car I was compelled to open the hood & check it out, until it basically drove me crazy.
Total job was a little under $1K. I opted for a Power Bond HB, aftermarket tensioner, and ARP bolt. Well worth it to me.
Could I have waited longer? Maybe. But piece of mind when you're far from home is priceless.
Old Mar 29, 2018 | 02:14 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Ops normal. You are good. That is more of a "quiver" than a wobble."
As, with all car systems, keep an eye on it.
