Can someone confirm engine mount nut torque spec?
Old Mar 23, 2018 | 12:28 PM
DK83's Avatar
DK83
Default Can someone confirm engine mount nut torque spec?
It's for a 2002 c5 z06
My GM manual isn't with me at the moment. Can some one confirm the torque specs on the engine mount nuts that goes under the car from the sub frame?
Is it 48ft/lb(is this for c6?) or 59ft/lb?
Thanks!
Old Mar 23, 2018 | 03:54 PM
glbeauchamp's Avatar
glbeauchamp
My list shows the following: Engine mount bracket-to-engine block bolts 50 n/m 37 ft/lbs.That's all I could find for engine mounts. Hopefully that's what you're looking for.
Old Apr 11, 2018 | 02:17 PM
DK83's Avatar
DK83
I believe 37 is the spec for the mount bracket to the block.
I have confirmed that the nut from under the car/subframe is 48ft/lb.
Thanks!
To Can someone confirm engine mount nut torque spec?
