Would these kind of cracks in the vacuum line ends be enough to throw a vacuum leak and a P0300 code? This is the line that runs from the passenger side valve cover area to the throttle body. The installed picture is not all the way on. It is at the flared part to better show the cracks when expanded. Once fully seated they close up more.
I would replace it if it were on my car... a better alternative would be some silicone hose if you can find it in that diameter, it won't dry up and crack like that and will last much longer
Thanks folks. I'll search up some silicone hoses for size. Worse case I'll get oem replacements. These lasted nearly 14 years. I have a feeling I will be pulling the intake manifold off to look for additional sources of leaks too. Guessing I'll have to just to replace this whole line anyway.
That line is the engines PRIMARY source of PCV Vacuum. The PCM is programmed to compensate for that metered air flow around the MAF.
IF,,,,,,,,,, the line is degraded / or leaks, the LTFTs will be high to adjust for the excessive lean condition.
The end of that line is showing you the condition /age of the entire line. In a pinch you could trim off a 1/4" or so of that line and it will seal there better BUT, the "Y" intersection at the rear of the intake manifold where the THREE PCV hoses join together frequently is dry rotted and cracked and can leak oil on the back of the engine and introduce a vacuum leak..
