Dorman Knock Sensor Harness?
Old Mar 27, 2018 | 01:27 AM
Scholioso's Avatar
Scholioso
Default Dorman Knock Sensor Harness?
Hey guys. So I have a 97. I read that the 97 to 98 knock sensors are aweful. So I plan on swapping to the 99 and newer knock sensors.
Tick has 2 knock sensors and a harness for $160. Yikes. I have two knock sensors that came with an engine I purchased and then sold. Part # 10456603 which I believe to be the newer knock sensors. Great, now I just need a new harness. First, is there even a difference in harnesses between 97-98 and 99-04? Either way, I found a Dorman harness for $20 on rockauto. Part #917-033. Anybody have experience with this harness or knock sensors? Let me know, thanks.
Old Apr 5, 2018 | 09:57 PM
old stingray's Avatar
old stingray
Are your sensors bad or are just wanting to replace them because of what you read? I used the dorman harness in my Avalanche with no problems. If your sensors are working don't screw with them,if you need to replace them don't buy aftermarket buy AC Delco.
Old Apr 6, 2018 | 01:32 AM
Scholioso's Avatar
Scholioso
I wanted to replace them due to what I read about the 97 to 98's being bad. So I did end up changing them & using the dorman harness. Everything works good so far. I discovered however that my car had the new harness & knock sensors already installed. However, the knock sensors that were in the motor were rusted & corroded. Plus, I did all this work, might as well, so I changed it all out. Everything feels good, I cleaned a lot up, intake is disgustingly covered in carbon/oil. So I might take it off again and let it sit in something to really clean it up. It's nasty. Which made me replace my homemade catch can with a better homemade one. Anyways, everything works, thanks guys.
To Dorman Knock Sensor Harness?
