Hyperflash or not when using hazard switch
Old Mar 28, 2018 | 04:47 AM
oelarse's Avatar
oelarse
Default Hyperflash or not when using hazard switch
Hello .
I have ordered and intend to install these modified LED Halo taillights .
I will also install the the harness with LED flasher shown below and due to this my turnlights will operates without hyperflashing .
But , what if I operate my hazard switch , will I get hyperflashing turnlights then ?
I hope someone who has installed these LED tailights can give me a feedback on this issue .
I have also ordered ordered this third LED brakelight .
Do I need to connect a load resistor ( 6 ohm 50w) on this brakelight to avoid alarm from my EBTCM module when I activate my brakes .
The EBCTM receive a voltage signal from the stoplampwitch and I guess the voltage level is different when you use LED instead of stock bulbs .
Old Mar 28, 2018 | 07:29 AM
3sACROWD's Avatar
3sACROWD
My experience is that the lights will hyperflash when using the hazard switch. Otherwise the turn signals work as normal.
Old Mar 28, 2018 | 09:58 AM
oelarse's Avatar
oelarse
OK . Thanks
Then I have to get me another EP29 LED Turn Signal Flasher Relay and figure out a modified schematic to avoid hyperflash when using the hazard switch
Old Mar 28, 2018 | 11:11 AM
3sACROWD's Avatar
3sACROWD
Originally Posted by oelarse
OK . Thanks
Just curious. Is there a need for you to have a regular rate flash for hazards (inspection) or just a preference? With LED lights, the hyperflash makes the car very noticeable and I actually prefer the hyperflash for hazards.
Old Mar 28, 2018 | 12:43 PM
Tsumi's Avatar
Tsumi
You won't be able to avoid it without modifying the flasher itself, or using load resistors. I can show you what I did to my flasher, but it probably is more than what you want to do. It involves basically gutting the thing, keeping only the spring-switch portion, and putting in momentary switches.
Old Mar 28, 2018 | 01:07 PM
GCG's Avatar
GCG
...I have ordered and intend to install these modified LED Halo taillights...
...I have also ordered this third LED brakelight...
...Do I need to connect a load resistor ( 6 ohm 50w) on this brakelight to avoid alarm from my EBTCM module when I activate my brakes?
The OEM 3rd brake light IS an LED assembly. Replacing it with another LED unit should not make a difference.
If your modified LED Halo taillights have the built-in resistors like the one shown below, no error code should be generated and no extra resistors should be needed for this purpose.
Old Mar 28, 2018 | 02:11 PM
oelarse's Avatar
oelarse
Thanks for your replies .
It seems like my LED´s have load resistors when I look on this picture from my ebay order and then my stock flasher should work without any hyperflashing ( I hope ).
To Hyperflash or not when using hazard switch
