Beat LS6 cam?
Old Mar 28, 2018 | 03:53 PM
MilsteadGC's Avatar
MilsteadGC
Default Beat LS6 cam?
Best cam for 2003 Z06 for street and light performance driving events? Would like to use standard exhaust to avoid excess noise since it is a street car 95% of time. Would like 400-425 RWHP with dyno tune if possible but adequate torque to maintain reasonable street manners. Are my expectations reasonable? Open to all suggestions and in particular real world experience over time. Please be as specific as to exact equipment. All help appreciated.
Old Mar 28, 2018 | 04:08 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Check out a Comp 224/230 on a 114+2 LSA
The +2 means that it has 2 degrees of cam advance ground into the profile. You install it like normal and reap the benefit.
I have this cam in my C5z and love it. I've had probably 4 cams in this car and it's my favorite. Drives like stock, doesn't have crazy lope but doesn't sound stock either.
Old Mar 28, 2018 | 04:38 PM
Carl Timonen's Avatar
Carl Timonen
Josh, do you have a sound clip?
Old Mar 28, 2018 | 06:35 PM
zeevette's Avatar
zeevette
A small cam will increase torque over a stock Z cam. I would suggest you get LT headers to optimize your new cam. You can be as quiet as stock, depending on which catback you choose. I suggest keeping your stock Ti catback, and getting a headers/catted midpipe combo that'll bolt right up to your catback, and retain almost all of the stock sound. (only better)
Old Mar 28, 2018 | 10:46 PM
Moved to C5 Tech.
Old Mar 29, 2018 | 07:59 AM
Georgies's Avatar
Georgies
MS4
Made 463/398 on Mustang dyno with longtubes and halltech killer bee 2
Old Mar 29, 2018 | 10:24 AM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
MS4 can turn some great #s but does not sound like what the OP wants.
What do you mean by standard exhaust?
Old Mar 29, 2018 | 03:51 PM
tigertank's Avatar
tigertank
anyone run a thunder nracing trex 242/248 .608/.612 110 lsa or something close to this? I understand piston clearance can be an issue
Old Mar 29, 2018 | 09:33 PM
MilsteadGC's Avatar
MilsteadGC
Thanks Josh. Sounds like what I am looking for. I want to retain the stock titanium exhaust if at all possible.
Old Mar 29, 2018 | 09:38 PM
MilsteadGC's Avatar
MilsteadGC
Standard headers and titanium exhaust if possible. I have ridden in several Z06's with long tube and big bore exhaust and the associated drone is too much for me (at my age).
Old Mar 29, 2018 | 09:43 PM
MilsteadGC's Avatar
MilsteadGC
Suggestion for best LT brand for least drone and decent sound?
Old Mar 29, 2018 | 09:48 PM
Time for a C-5's Avatar
Time for a C-5
Lots of extra exhaust duration if you keep the factory manifolds. Your factory cam has an extra 14 degrees of exhaust duration.
You could also replace your factory manifolds with LS7 manifolds if quiet is your goal. There's usually some for sale in the C6 section. You'll need some custom work to the midpipe for fitment. That would add power and keep it quiet. I bet those manifolds a cold air and a tune could be worth 30+/- hp w/out opening up the motor.
Old Mar 29, 2018 | 10:30 PM
Georgies's Avatar
Georgies
Ok these vids are without tune, stock TI catback and ARH 1 7/8 LT headers no cats. With cats itll be more docile.
I think my Z is the best sounding C5 on the planet.
Your welcome.
Old Mar 30, 2018 | 02:34 AM
NSFW's Avatar
NSFW
Your welcome.
What RPM do you cruise at on the freeway with that cam? Does it still run smoothly at 2000 RPM or so?
That's the kind of thing that worries me about big cams... I want it to still be fun to drive 3 hours to the track.
Old Mar 30, 2018 | 02:59 AM
Georgies's Avatar
Georgies
It drives great! When i was debating what cam to go with last summer, the one thing that kept coming up was "its all in the tune" and it was true.
Old Mar 30, 2018 | 07:21 AM
Georgies's Avatar
Georgies
At 120 kms/h im at about 1200k. Yeah its smooth. In all honesty, you will be happy with almost any cam you get as long as its well tuned. Do you ever plan on going forced induction? The MS4 is spectacular with Nitrous and also very good if you plan on getting heads and staying NA. If I ever did it again, id go with either EnglandGreen or Ed Curtis. I was not happy with the service from TSP, but the cam is great!
Old Mar 30, 2018 | 07:48 AM
wrkdWS6's Avatar
wrkdWS6
OP, there’s some good and bad info in here. As for a cam, it sounds like something in the 220’s intake duration range is probably going to be your best bet. Any more than that will begin to really sacrifice power and torque in the lower rpms just to move it to the upper rpms which I suspect you may not care for. Big cams are fun in the high rpms but when compared to a car with a smaller or medium sized cam they really leave a lot to be desired until they kick in at say 4,000 rpm. Been there done that.
Overlap determines the driveability so you may not want to go too crazy there (say +6 degrees at the most or so). A lot of the driveability is in the tune but a tune can only do so much depending on what you are working with.
There are many great options to choose from that should fit the bill well for you. I prefer Cam Motion, check out their Titan 3 and Titan 4 cams. I also suggest giving them a call and seeing what they think would be best for you.
As for exhaust, the drone comes from the mufflers. As long as you are running the factory Ti mufflers you will get no drone. I have LT headers, no cats, Ti exhaust with the bypass mod and a cam and have zero drone. It’s quiet when cruising on the highway. I would choose the brand of headers based upon ease of install, quality and your budget.
To Beat LS6 cam?
Old Mar 30, 2018 | 07:51 AM
wrkdWS6's Avatar
wrkdWS6
Your welcome.
If you think your car sounds good now you should consider the Ti bypass. Makes them sound 10x better. One of the best things I did.
Old Mar 30, 2018 | 08:28 AM
wrkdWS6's Avatar
wrkdWS6
I don’t mean to take a shot at you but you are providing very unsuitable advice. The MS4 is a max effort LS1/LS6 cam designed for people who want the absolute highest dyno number possible and/or the best possible track time. With that are major drawbacks. That cam is a poor choice for the vast majority of people. It may be perfect for your needs but that doesn’t mean it is for the next guy. If I gave investment advice that was that unsuitable to my clients when I worked as a stock broker, I would have been fired, sued and stripped of my licenses. It’s like telling a retired 85 year old woman who lives and relies on her retirement nest egg to put all of her assets in stocks.
Old Mar 30, 2018 | 08:33 AM
R.c. Ness's Avatar
R.c. Ness
I have 3 suggestions for you (in this order):
1) Tick Performance "SNS" torqueMAX Stage 1: 223/227 | .610"/.590" | LSA111+2
2) WS6store Hot Cam: 218/227 .600/.600 112+2 LSA
Considering your stock LS6 Cam specs; 207/217 @.50 .525/.525 lift 116 LSA (2002 – 2004) - If you don’t like the high lift of these first two (requiring new springs), I would go with:
3)Lingenfelter LS1-GT1 Cam specs 218/229@.050 .561/.561 lift 113 LSA.
Personally; I’m a sucker for high lift & moderate duration – I just LOVE torque
I have the mod that Time for a C-5 talked about: LS7 exh manifolds & Ti catback, CAI & a good tune.
Nice, quiet, stock-looking 400+RWHP
