Ignition system clean no start
Old Mar 28, 2018 | 03:55 PM
mikesvette1's Avatar
mikesvette1
Default Ignition system clean no start
I followed the instructions on cleaning the contacts on the ignition system, installed and accessories lite up and then turned key to start, nothing checked codes and i Had B2327, so i went and got the TDR and replaced it. still doing the same all systems come on but no start. what am i missing. Its gotta be something simple, going to order new cylinder tommorrow but i would like to know what i'm missing.
Old Mar 29, 2018 | 11:20 AM
twokbolt's Avatar
twokbolt
STOP! Replacing parts. Pull the codes again. I could not find B2327. When you say it doesn't start does the engine not even turn over? What is the security light doing while you are trying to start?
Old Mar 29, 2018 | 12:15 PM
mikesvette1
Thanks for responding, I'm getting b2723 code and accessories works and then on works but then nothing at start. I have reset the codes and B2723 comes back as fast as I reset it and the surity light stays on solid from the time I turn the key on.
Old Mar 29, 2018 | 03:04 PM
mikesvette1
Thanks, by bypassing are you talking about cutting the two white wires and connecting them together to make a circuit. I really do appreciate your time and help.
Old Mar 29, 2018 | 03:21 PM
v6turbo87's Avatar
v6turbo87
You can't just cut the wires and splice them. You need to measure the resistor pellet on you key and put a resistor of the same value between the wires. This will bypass the contacts but still send the correct resistance value to the BCM so the VATS system will be satisfied.
Do a search for VATS bypass on YouTube and you will find videos on how to do it.
Old Mar 29, 2018 | 03:33 PM
mikesvette1
ok thanks
Old Mar 30, 2018 | 12:09 PM
mikesvette1
Thanks for the help. I found the right resistor and now car is running great, now I will put it all back together this weekend.
Old Mar 30, 2018 | 01:51 PM
1997 C5's Avatar
1997 C5
Photo of the process by pass would of been nice in case I have to do this in the future.
Old Mar 30, 2018 | 04:34 PM
mikesvette1
I'll try to get photos today, and put something together.
To Ignition system clean no start
