Hydraulic clutch problem
Old Mar 30, 2018 | 10:52 AM
Hal-2's Avatar
Hal-2
7th Gear
Default Hydraulic clutch problem
Hello- this is my first time on this forum. I recently took my 2000 c5 out of storage. Upon starting it the clutch did not seem to dis engage and it then stuck to the floor. I had to physically pull the clutch up with my hand. The car stalled so I restarted it and the car lunged forward as it turned over. I replaced the fluid in master cylinder. Restarted car with clutch in and allowed it to warm up. After about 15 seconds the clutch seems to engage on its own without me releasing it. Has anyone experienced this problem? Or have suggestions? Many thanks. Hal-2
Old Mar 30, 2018 | 11:02 AM
3sACROWD's Avatar
3sACROWD
Without being able to look at your car, my first impression is your master cylinder is shot. If you can do the work yourself, it will cost you $100 if you go with a stock replacement. It isn't a bad job.
Check to make sure you aren't dripping fluid from the area just behind the engine. If you are dripping fluid there, your slave cylinder is likely bad. Start with the least costly option first
Old Mar 30, 2018 | 11:10 AM
Hal-2's Avatar
Hal-2
7th Gear
Thanks very much. I have been doing some research and it appears that this may be the case. I don’t have the facilities to do this myself so I am putting myself at the mercy of a dealership. I was hoping it was just air in the line but even bleeding it seems like an intimidating task. Thanks for your response.
Old Mar 30, 2018 | 12:33 PM
3sACROWD's Avatar
3sACROWD
If you have a floor jack, that is all the facilities you need.
Old Mar 30, 2018 | 12:59 PM
001pewter's Avatar
001pewter
St.. Jude Donor '17-'18
Just a jack a few tools and some patience. Not a hard job, just take the tire off. Getting the line apart was the hardest for me. It's a quick disconnect type and I used a piece of a old bycicle fork and it came right apart.
Old Mar 30, 2018 | 04:46 PM
OleStraightStick's Avatar
OleStraightStick
St. Jude Donor '08
I think mine is on it’s last leg.. might wanna consider the Tick Performance master cylinder.. that’s what I’ll most likely eventually install in mine.. it’s right at $300, and is a slightly more complicated install, but seems to be what many prefer.. no restrictive lines so fluid flows at a faster rate, and it’s adjustable
Old Mar 30, 2018 | 08:23 PM
Hal-2's Avatar
Hal-2
7th Gear
I have done a bit of reading on that. It does sound like the way to go. Thanks for your input!
Old Mar 31, 2018 | 12:12 AM
Moved to C5 Tech.
Old Mar 31, 2018 | 11:24 AM
Gordy M's Avatar
Gordy M
Quite often it is the Master Cylinder that is the culprit, if not it is the Slave Cylinder (throw out bearing). With a stock engine, the C5 MC would be the way to go, if you have head/cam then the Tick MC would be the better option. If you are stock and have no desire to add H/C to the Corvette then Stock MC is the easiest way to go.
If the Slave is leaking then have several friends to help you or go to a shop experienced in Corvette clutch replacement. There are numerous threads on DIY clutch replacement--if you are going to replace the slave you might as well replace everything at the same time.
Old Mar 31, 2018 | 12:01 PM
Hal-2's Avatar
Hal-2
7th Gear
Thanks for the in put. It all seems to point to the master cylinder. I flushed the clutch fluid using the multi pump clutch method. The fluid finally ended up clear. However I still have the original problem. I have an appointment with the dealer for Monday morning to have it trouble shot. I really appreciate all the responses I have had on this issue. Thanks to all. So nice to have a forum like this.
Old Mar 31, 2018 | 03:51 PM
3sACROWD's Avatar
3sACROWD
One thing to note is the effort required to depress the pedal increases with the TICK MC. I don't mind the trade off but others who drove my car before and after give the new feel mixed reviews.
Old Mar 31, 2018 | 05:17 PM
Hal-2's Avatar
Hal-2
7th Gear
I don’t think the extra tension would bother me. I am going to ask about it when I take the car in on Monday morning. Thanks and cheers!
Old Mar 31, 2018 | 09:03 PM
wasp74820's Avatar
wasp74820
I just repaired this problem on my own and the worst part of it for me was removing the roll pin. I had about 2 seconds of clutch before it bled down with no fluid loss. Tear down exposed globs of clutch dust, pitted cylinder and blown front cup. Now I know to change the fluid but it lasted 18 years so can't complain about that. 157k miles.
Old Apr 1, 2018 | 06:00 AM
Hal-2's Avatar
Hal-2
7th Gear
Mine is just under 100 km. The clutch fluid was pretty dark. The first thing I did was to flush the fluid but no luck. At least I can speak with the service dept with a little bit of knowledge behind me. I just bought the vehicle last Aug. it seemed great but when I look back I can remember a few occasions where it would grind a very slight amount when going into reverse. I thought it might be just me not being diligent with the clutch. Put it up in November and it was great. Just sitting there must have deteriorated. I’ll take it in tomorrow. Thanks to all!
Old Apr 2, 2018 | 03:53 PM
johnson-rod's Avatar
johnson-rod
It's the years not the miles.
Old Apr 2, 2018 | 05:43 PM
Hal-2's Avatar
Hal-2
7th Gear
An update to my original thread: the dealership found the slave cylinder to be leaking. They strongly suggested that the clutch plate be replaced so I bit the bullet. Once the tranny is lowered the clutch plate is right there so it made sense. I don’t plan on getting rid of the car any time soon so it’s a little piece of mind. Once again thanks to all who offered their input to this problem.
To Hydraulic clutch problem
