over heating problem
Old Apr 3, 2018 | 10:35 AM
Vern11's Avatar
Vern11
5th Gear
Default over heating problem
When I'm in stop and go traffic my temp spikes. Clean air on the interstate is all good. Is this the thermostat or one of the relays? I've heard both. Thanks
JT
Old Apr 3, 2018 | 10:47 AM
Robrote's Avatar
Robrote
Check the area in between the radiator and the AC condenser. They are notorious for clogging with road debris. You'll need a long handled soft bristle brush to clean it and or a power washer.
Old Apr 3, 2018 | 10:57 AM
Vern11's Avatar
Vern11
5th Gear
Default Over heating
I'll check that out, thanks for the tip
Old Apr 3, 2018 | 11:01 AM
jcgunn's Avatar
jcgunn
What do you mean by "overheating?" Normal ops is about 192 on the road and 220-225 in the drive-thru at burgerland.
Old Apr 3, 2018 | 11:06 AM
Velocity_Vette's Avatar
Velocity_Vette
Yeah define "overheating". 220-230 is not overheating.
Vern11's Avatar
Vern11
5th Gear
it gets over 225 in summer with a/c on in traffic. Relays looked good, thought about putting a new thermostat in
Old Apr 3, 2018 | 11:07 AM
Vern11's Avatar
Vern11
5th Gear
Originally Posted by 8VETTE7
Definitely do NOT use a high pressure washer on the radiator to clean it unless you want to replace it.
Low pressure from the engine side toward the front of the car to dislodge any debris that has been thrown up against the radiator fins. C5's are bottom breathers and suck up anything on the road and that is the most likely cause of heaing in traffic.
However I would also start with insuring the surge tank has coolant up to the "COLD" mark on the end of the tank.
Old Apr 3, 2018 | 07:26 PM
Vern11's Avatar
Vern11
5th Gear
Default Thanks
I cleaned out the fins on the radiator w/an air hose and it fixed the problem. Thanks for the advice!
JT
To over heating problem
