Converting my C5 to strip only and I'm entertaining the though of losing the alternator. Anyone done this and how long can the car go without the battery going dead?
Does it rob that much power? Ditch the battery instead?
Yea it's a good point. I'm trying to free up as much stuff on the motor as possible to allow for more room and less weight. But the more I'm reading, the more I'm feeling this is a bad idea (fuel pump being electric is one). The other thing I have to figure out is if I keep the alternator, how can I run another bracket smaller/lighter than the bracket it's on since I ditched the power steering.
Keep in mind, that most electronic ignitions need ample power, 100% of the time, to perform at 100% efficiency. Lose the alternator, and you lose that power, especially when you'll probably be running an electric fuel pump..........
Thanks,
Way back in the day (30 ish years ago), I worked on several nationally competitive Showroom Stock race cars. One of the more well known "cheater mods" was the 10.xV voltage regulator. The regulator would be modified so it wouldn't charge above 10.8V or so (maybe a little less), and The battery would be fully charged (13.5V to 13.8V) at the start of a race or qualifying session. It'd still have to spin the belt and pulleys, and the armature in the alternator, but there was no load on the engine to charge anything because the stator coils were de-energized.
Generally, the battery would come back after a 15 minute or 20 minute session still well above 11.5V. Sometimes it would last for a full 35(ish) mile regional race and still be over 11 volts, but usually, it was back charging (at the lower voltage) by the end of a 45(ish) mile national race.
I've seen that mod on German and Japanese 4 bangers, Mazda 2 rotor engines and even some Japanese inline six engines. I've never done that on a Corvette, or any American V8, but I can't imagine the results would be much different. Todays batteries (especially if you go with a light weight Lithium Ion battery) are better, and it would probably run longer.
I ditched the PS and relocated the ALT to the AC position. Used a Ford Explorer alternator driven by a 4 rib belt. Added an electric water pump, so there's no need for the main serpentine belt. There's a thread somewhere around here on it.
Alternator relocation info: https://www.corvetteforum.com/forums...nger-side.html
Cool thanks Chris, I like your setup! Thanks for the link, that is one I found originally but I missed the text in there that talked about the wiring, I will give that a shot.
Looks like you did steel braided lines for the transmission cooler? What electric water pump did you go with?
I don't think you will gain enough to lose it,you need a fully charged batt to run the ign.,and some tracks you cant find power outlets,are you going to carry a gen? ,,the less things you can bring with the easier things are at the track
unless you load everything in your race semi and 53' trailer
