Check engine light after battery change
Old Apr 6, 2018 | 08:04 AM
cwf04vette's Avatar
cwf04vette
Default Check engine light after battery change
Installed a new battery yesterday and when I started the car the "check engine" light is on steady. I think it's because of the installation of a new battery but not sure. Before I take it to the dealer is this something I can check and clear through the messaging system?
Old Apr 6, 2018 | 09:05 AM
grantv's Avatar
grantv
Did you run for codes? Do a search of unsure how...
Old Apr 6, 2018 | 09:36 AM
JR-01's Avatar
JR-01
Turn on the ignition but don't start the engine.
Press the "reset" button to turn off any warning messages
Press and hold "options" and
While holding "options", press "fuel" four times within a 10-second period.
Write down codes and then clear them.
http://www.stengel.net/diccodes.htm
http://www.c5forum.com/ayc/dtcdic.php
Old Apr 6, 2018 | 09:57 AM
02BlownZ06's Avatar
02BlownZ06
Use the DIC to pull the code(s) and see what they are. More than likely just a loss of communication code or the like from the battery swap and they just need to be cleared out.
Old Apr 6, 2018 | 10:55 AM
Moved to C5 Tech.
Old Apr 6, 2018 | 12:01 PM
cwf04vette's Avatar
cwf04vette
Moved to C5 Tech.
Thank you Vetteman. Sorry for the wrong location.
Old Apr 7, 2018 | 10:59 AM
mmartinez's Avatar
mmartinez
Have you tried disconnecting the battery for 5-10 minutes, most of the time when connecting battery, electrical connection is made and then broken several times when securing the last cable on to the battery, which could have set some codes.
Old Apr 8, 2018 | 07:26 AM
cwf04vette's Avatar
cwf04vette
I followed the instructions on how to clear the codes and the check engine light went out. Thank you everyone for the, as always, good advice. Now if the weather would break and the roads/potholes would get fixed I'm ready to go riding.
To Check engine light after battery change
