Issues with Viking coilover fitment?
Old Apr 8, 2018 | 07:46 PM
all4spl's Avatar
all4spl
Default Issues with Viking coilover fitment?
Finally got the coilovers on but have run into a few snags. Wanted to run somethings by you guys before I make adjustments. It seems the springs hit body parts on both front and back. The front has the spring hitting the shock boxes at the top where it gets bolted down with the single nut on top. With the car off the ground, the coil binds agaisnt the frame of the car which may not be good when the car launches hard. The rear has the coil hitting the upper control arm at full droop. Which won’t be an issue when the car is on the ground I’m hoping but wanted to run that by you as well. Have you had issues on the c5 corvettes?
Old Apr 8, 2018 | 10:56 PM
Moved over to C5 Tech. Hope you get an answer to your problem.
Old Apr 8, 2018 | 11:14 PM
jumpmanmb87's Avatar
jumpmanmb87
Some pictures would help us or the kit you have. I have them and I don't have any fitment issues. The rear maybe some close clearance and that's it
Old Apr 9, 2018 | 08:37 PM
6speedsteve's Avatar
6speedsteve
Did you buy these new or used?
If used, did you have proper instructions?
Do you have the correct version for a C5?
Did you call the manufacturer with your issue?
As stated above pictures would help.
Here is another thread with some fitment issues, C6
https://www.corvetteforum.com/forums...em-anyone.html
Old Apr 12, 2018 | 09:28 PM
junk c5's Avatar
junk c5
FWIW. I just installed the warrior valved double adjustable coilovers on the front of my C5 today. When in the air the springs did rub the insides of the upper A arm. I turned the spring and it is now about an eyelash away from rubbing the inner A arm. I’m not using a sway bar so there’s no rubbing there. I did look to see how close it is on the ground but I did test drive it and everything felt good.
To Issues with Viking coilover fitment?
