Lambda sensor (o2) question.
HOWEVER, that said, if they are failing prematurely, you have issues. The HEATER CIRCUIT for the sensors MUST work properly for the sensors to function and not fail prematurely.
IF, your are failing like that, I bet you a cold one that your heater voltage is NOT functioning properly. I will attach the schematic that you need to troubleshoot this circuit. You have to make sure that you have FULL BATTERY VOLTAGE on the O2 sensor heater FUSE when the IGNITION SWITCH is ON and have a fully functioning ground circuit to chassis ground.
The COMMON failure points are:
Faulty ignition switch: The Switch supplies the (HOT in RUN/ON) voltage to the FUSE when the key is ON!! You should see FULL battery voltage on the two test points on top of the FUSE to chassis ground. If you don't, the ignition switch is BAD!!!
The ground path for the circuit and have corroded points in the Splice Pack and or the actual chassis ground.
If it were ME, that's where I would start, even before you install the new O2 sensors.
BOSH and NGK are the brands that I would go with!
I run BOSH and have NOT had any complaints and I have a heavily modded engine.. They last a LONG time in my car!!
SCHEMATIC:
Bill
Not sure if this helps.......but the readings were only very slightly high.....but high enough to effectively cause it to fail. The only way we could get the reading to come within spec was to raise the engine revs quite high....around 4000.....it gradually fell and just crept within spec. However, it appears to be getting closer to the point of failing. The garage said they thought it was due to the type of driving I generally do.....just short leisure driving rather than out on the motorway......it is generally used for fine days only.
Things that cause them to fail are.
- Running leaded fuel
- Failed heater circuits
- Running very rich
- Burning a lot of oil. (engine oil consumption problems)
- High Mileage
BC
The reason I ask is that I suspect that your sensors are fine, and that your catalytic converters are what is starting to fail. If you're revving to pass inspection, you are bringing the cat's temperature up, increasing conversion and bringing you within emissions spec.
TLC. Maybe Filters, fluids, Ignition Tune Up..
Your plugs and wires may not be 100% causing higher emissions.. And even
having dirty/old oil can cause higher emissions.. Do the simple maintenance first
Product example below:
Do some good ole high performance acceleration runs (you don't have to do 200 mph to clean out the combustion chambers) Just some 0-60 WOT runs.
If all that fails, you may have to do new replacement CATs
Bill
An engine with high hydro carbons is simply running to RICH at P/T or in what they call "closed loop" Closed loop is where the front 02's have full command on your engines fueling and makes adjustments based on the front 02 voltages by making corrections to your fueling using your "fuel trims" The ECM at P/T is always trying to achieve the STOICH fuel ratio of 14.68-1
Many things can cause your engine to run rich
bad or slow front 02 sensors
Not working front 02 heaters
Carbon'd up combustion chambers
Too much oil in your intake manifold coming from your PCV system
Fouled MAF caused by oil fouling from a cold air oiled filter
I would 1st seafoam your engine--one can into a full tank and another can into a quick pour into your intake manifold via your brake booster line
Typically a BAD CAT will increase mostly your NOX readings and not so much your hydrocarbons
Someone with a wideband set up can read your actual P/T AFR ratio --that will give you a head start on what may be wrong
ALSO anyone with a basic scanner can read real time 02 voltages to see in fact if they are working properly A 02 sensor voltage should rapidly "oscillate " or change between .100 to .950 millivolts With an AVERAGE voltage between .400 and .500
A bad 02 will flat line at .450 or oscillate very slowly
Do you have LT headers ???? If so THAT is your problem and requires a whole other fix
Doubtful your O2 sensors are bad after 35K. CEL illuminated ??... Do you have a scanner where you can read O2 sensors, and long/short fuel trims ??...without interpreting this info you are pretty much shooting in the dark...O2 sensor circuit pretty easy to diagnose (heater and signal)..now which "readings" are you talking about...tailpipe emissions ??...now as far as raising engine speed and seeing your "readings" improve normally would be a vacuum leak...you would see this by your long term/short term fuel trim improving as RPM increased...like I said without being able to see this info you're be just shotgunning !!
