Whats next
Old Apr 12, 2018 | 09:51 PM
Adavis's Avatar
Adavis
Default Opinions necessary
Forgive me if this is a repeat question. Im not having much luck searching. I rescently purchased a 01 automatic with 50k. I have it at the shop now getting headers, high flow cats, xpipe, Ti axle back, vararam cai, cam, and tune. Im not posative what size cam. I was told it is the most aggressive I can do without torque converter or drivability issues. So my question is whats next in the way of more hp/tq? Is Fi next? If I do go with Fi, will I be able to purchase kit, install, and tune, Or will I need to upgrade many more parts? I think ill be happy with 500-600 rwhp. Thanks for any input.
Old Apr 12, 2018 | 11:30 PM
Moved to C5 Tech.
Old Apr 13, 2018 | 11:05 AM
Adavis's Avatar
Adavis
Old Apr 13, 2018 | 10:21 PM
Adavis's Avatar
Adavis
Anything
Old Apr 15, 2018 | 08:58 AM
Adavis's Avatar
Adavis
Ttt
Old Apr 15, 2018 | 09:12 AM
tbrowne's Avatar
tbrowne
Trans is next. You'll need to beef up the trans at some point to handle the power. You will also want a torque converter with a higher stall and possibly lower gears in the back. 3.42 gears seem to be the best option for an auto. Be sure to install a new harmonic balancer while the cam is being installed. Balancer failures are very common and they are easy to replace when the cam is changed.
Old Apr 15, 2018 | 02:52 PM
Chicago1's Avatar
Chicago1
If you really want more power do a blower keep the boost mid/low so your not having to upgrade anything else down the line. if you get a cam then you may have to do gears and converter which cost more money. Nice A&A or ECS kit and forget about it call whomever you are closer to since you don't have your location in your profile.
Old Apr 16, 2018 | 06:44 AM
Adavis's Avatar
Adavis
Thanks for the advice. Im in east TN, I will edit my profile.
To Whats next
