Transmission
Old Apr 15, 2018 | 02:18 PM
Molly rivera's Avatar
Molly rivera
2nd Gear
Default Transmission
My c5. Just noticed when you take off shifts aggressive from take off like first gear kind of jerks at take off
Old Apr 15, 2018 | 06:41 PM
Grandpa1's Avatar
Grandpa1
Dang, you need to get that fixed.
Old Apr 15, 2018 | 08:09 PM
namvet6869's Avatar
namvet6869
My 2000 shifts hard from 1 to 2 under normal driving. When I punch it hard it shifts normal. Hope that is its nature.
Old Apr 16, 2018 | 03:32 PM
63Corvette's Avatar
63Corvette
I assume that you are referring to an AUTOMATIC transmission???
At any rate, the solution is driver modulation of the gas pedal
Old Apr 16, 2018 | 07:10 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
A couple things Whenever you have a transmission fault of any kind the ECM will compensate to allow you to get home by setting the line pr essure at FULL MAX (90 PSI)
This creates hard almost violent shifts
Also when the trans fluid is cold the ECM commands a shorter shift duration to compensate for the cold fluid This should disappear once the fluid warms up
Finally as a car ages the stock trans shifting procedure may become either too soft or aggressive A trans tune can fix all shifting abnormalities as long as you don't have any serious mechanical issues
To Transmission
