Throttle Position Sensor question
Old Apr 15, 2018 | 11:10 PM
EA-sports's Avatar
EA-sports
Default Throttle Position Sensor question
Hi all, I got the P1221 and P1120 code which I think indicated bad TPS. Is the TPS for C5 Z06 same as the non-Z06? I have a 2003 Z06 and looking at Rockauto.com it looks like the TPS is the same for C5 Z06 and non-Z06. Do you all think this is the right part https://www.rockauto.com/en/moreinfo...n=456&jsn=456?
Any other source other than Rockauto I need to look at?
Thanks all.
Old Apr 16, 2018 | 12:41 AM
TastyBacon's Avatar
TastyBacon
It is the same part. I haven't replaced one before, but that appears to be the correct replacement. I usually check RockAuto against Amazon, but that looks like a very good deal, probably won't beat it.
Old Apr 16, 2018 | 09:43 AM
EA-sports's Avatar
EA-sports
Thanks for the Amazon idea, I don’t know why I didn’t think of Amazon for car parts. I ended up getting the Standard Motor Product one from Amazon since it was much cheaper compared to Rockauto and I read that the Delphi one I was going to order might not work. Will I need a special torx bit for this to change the TPS?
Old Apr 16, 2018 | 09:45 AM
getherejune's Avatar
getherejune
looks like the same one i just put in mine (non zo). Had the same codes as you, plus i would get the active handling message and limp mode (embarassing getting passed on the freeway by a prius ). Make sure you have the tamper resistant torx bit!
john
Old Apr 16, 2018 | 05:04 PM
TastyBacon's Avatar
TastyBacon
Harbor Freight sells a bit set that includes tamper-resistant Torx.
Old Apr 16, 2018 | 07:00 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
The best website to help diagnose DTC codes is Gearchatter
The have technical stuff but also have some plain English diagnostics that give you some simple help Type in " gearchatter.com DTC p1221 " and the p1120
To Throttle Position Sensor question
