C5 Headlight vertical adjustment
Old Apr 19, 2018 | 03:35 PM
Clancy209's Avatar
Clancy209
Default C5 Headlight vertical adjustment
Hi,
When trying to adjust vertical position of drivers headlight. everything turns the threaded rod is rotating but, does no go in or out (fwd and or aft).
This gear box appears to be attached to the headlight assy by some bolts, can this be changed independently or do i need a new headlight assy?
Thank you
