Left headlight
Old Apr 21, 2018 | 03:55 PM
Looking Up's Avatar
Looking Up
Navigator
Default Left headlight
Left headlight won`t go down
Old Apr 21, 2018 | 04:17 PM
Vanover's Avatar
Vanover
Is it grinding or completely dead? We need a little more information. There is a manual adjustment **** under the plastic cap you can turn to get it down.
Old Apr 21, 2018 | 05:07 PM
DDaaryl's Avatar
DDaaryl
Occasionally one of mine won't go up and turning the manual **** on top brings it back to life. Possibly a dead spot on the motor but only happens once a year or so.
Old Apr 21, 2018 | 10:01 PM
Moved to C5 Tech.
Old Apr 22, 2018 | 01:18 AM
UM Rebel's Avatar
UM Rebel
Tell us more.
Old Apr 22, 2018 | 02:53 PM
Looking Up's Avatar
Looking Up
Navigator
Default Headlight
Originally Posted by UM Rebel
Tell us more.
The headlights go down but the left one goes back up.I can lower it manually
Old Apr 22, 2018 | 02:57 PM
Vanover's Avatar
Vanover
Are you saying it goes down then comes back up automatically? Maybe bad bump stops.
Old Apr 22, 2018 | 03:03 PM
GCG's Avatar
GCG
Have you checked the 4 rubber bump stops? You might need to replace them.
Also, there is a TSB, that calls for shimming the driver's side motor to fix what you are describing.
Old Apr 22, 2018 | 03:17 PM
UM Rebel's Avatar
UM Rebel
So you turn lights off. They both go down but the left one pops back up and if you lower it manually it stays down. Is that what is happening? If so, this will be an interesting thread. It may be a failing Head Light Control Module. Here is a post I did last year. Trouble shooting procedure my help you find problem. I'm not saying you should fix it the way I did if it turns out to be HCM. But then after a year my fix is still working perfectly.
https://www.corvetteforum.com/forums...ol-module.html
Old Apr 22, 2018 | 08:21 PM
Looking Up's Avatar
Looking Up
Navigator
Default Headlight
Thank you i`ll check into it
Old Apr 22, 2018 | 11:04 PM
Tsumi's Avatar
Tsumi
Most likely is the bad bump stops. It goes down, but keeps rotating, which brings it right back up.
Old Apr 23, 2018 | 02:02 AM
Caveboy's Avatar
Caveboy
Active Streak: 90 Days
Check the headlight bumpers
Old Apr 23, 2018 | 11:08 AM
UM Rebel's Avatar
UM Rebel
If it's missing the down bump stop you will be able to tell by manually lowering. If you can keep on turning after light is fully down and continuing to turn light will come back up. If you can not turn anymore after it's fully down, bump stop is ok.
I'm thinking if that's what's happening then when you turn lights back on light would do just the opposite. That is it would go down then go up again. .
Old Apr 23, 2018 | 11:27 AM
GCG's Avatar
GCG
As I mentioned above in Post No. 8 there is a TSB (Technical Service Bulletin) from GM addressing these very same symptoms in the driver's side headlight.
Old Apr 23, 2018 | 01:08 PM
Tsumi's Avatar
Tsumi
Usually the bump stops wear down on one side and not the other. They'll stop properly when going up, but not when going down. Also, the manual test is not a reliable one because you'll be able to feel the resistance of the stop, but the motor can overpower it if it is just marginal.
Old May 10, 2018 | 02:47 PM
UM Rebel's Avatar
UM Rebel
Just wondering if you found problem. If so, what was it?
To Left headlight
