Clutch Inspection Cover Bolt Replacement
Old Dec 21, 2004 | 05:34 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Default Clutch Inspection Cover Bolt Replacement
I seem to have lost the two large bolts that hold bolt the inspection cover to the oil pan/block. Anyone know the size of these bolts (length/thread)?
Old Dec 21, 2004 | 05:43 PM
Dope's Avatar
Dope
Resident moron
Which 2? I seem to remember there being empty holes in my inspection cover when I did the clutch. I may have lost the bolts too or maybe we never had them.
Dope
Old Dec 21, 2004 | 05:54 PM
Patches's Avatar
Patches
I believe they are M10x1.50x40 mm. GM part no. 11516862.
Old Dec 21, 2004 | 07:07 PM
98vert6spd's Avatar
98vert6spd
How Tough Was It To Replace The Clutch?
Old Dec 21, 2004 | 07:22 PM
Patches's Avatar
Patches
Difficult - no. A lot of work - yes. Easier on a lift, for sure.
Old Dec 21, 2004 | 08:49 PM
98vert6spd's Avatar
98vert6spd
how much time are we talking with say 4 jackstands?
Old Dec 21, 2004 | 10:09 PM
Dope's Avatar
Dope
Resident moron
Depends on your level of skill. First time, with the right tools, probably a good 16 hours or so.
Dope
Old Dec 21, 2004 | 10:26 PM
SideStep's Avatar
SideStep
NO WAY we could have done it with out you...
Old Dec 21, 2004 | 11:23 PM
98vert6spd's Avatar
98vert6spd
i can pull a motor and it wouldnt be my first clutch job
ive done a fwd
but never a rwd
Old Dec 21, 2004 | 11:27 PM
Dope's Avatar
Dope
Resident moron
Read my install guide and see what you think then:
http://fear.net/~dope/c5_clutch_install_nopics.html
Dope
Old Dec 21, 2004 | 11:46 PM
98vert6spd's Avatar
98vert6spd
thats alot of ****to have to do
I can do all that but wow that is alot to have to do
How much do they charge at a shop for that?
Old Dec 22, 2004 | 12:03 AM
Dope's Avatar
Dope
Resident moron
Depends. Seems the average is around $750.
Dope
Old Dec 22, 2004 | 12:44 PM
5 Liter Eater
St. Jude Donor '11
Dope
That's weird that you have empty's too. Perhaps they are prone to vibrating out? They are the lowermost holes (one right by the oil filter in Patches' picture) facing forward in patches' top picture and can also be seen as the bottom most bolts in patches' bottom picture.
Anyone think I'm causing any harm by not having these? I can't see them providing a great deal of structural integrity.
Thanks for the bolt specs and part # Patches!
Old May 9, 2018 | 07:25 PM
Georgies's Avatar
Georgies
Whats the torque specs for the clutch inspection cover bolts?
Old May 9, 2018 | 10:56 PM
Moved to C5 Tech.
Old May 10, 2018 | 08:10 AM
feeder82's Avatar
feeder82
18 ft lbs
Old May 10, 2018 | 09:08 AM
Georgies's Avatar
Georgies
Originally Posted by feeder82
18 ft lbs
Including the 2 bigger bolts?
Old May 10, 2018 | 01:49 PM
feeder82's Avatar
feeder82
Out of my fsm engine flywheel inspection cover bolts 18lb ft no mentions of size
Old May 10, 2018 | 03:21 PM
Georgies's Avatar
Georgies
Ok thanks very much!
To Clutch Inspection Cover Bolt Replacement
