Best new 1/4 MPH!
Old Oct 17, 2002 | 11:16 AM
Scott97's Avatar
Scott97
Default Re: Best new 1/4 MPH! (EuG)
Good run. :cheers:
Glad to see more people try to run it on street tires – the way it’s driven on the street. :D
Its definately a good indicator of what your car will do. :yesnod:
Old Oct 17, 2002 | 11:22 AM
C5Noir's Avatar
C5Noir
Default Re: Best new 1/4 MPH! (Scott97)
Good run. :cheers:
Street tires all the way ;)
Old Oct 17, 2002 | 04:04 PM
ledfoot's Avatar
ledfoot
Default Re: Best new 1/4 MPH! (C5Noir)
Holy rear wheel horsepower Batman!!!
What the hell did demon do to your car...Those numbers are off the charts! :D
David in Indy
Old Oct 17, 2002 | 04:47 PM
C5Cemo's Avatar
C5Cemo
Default Re: Best new 1/4 MPH! (ledfoot)
Very nice #s! Congrats Scott :cheers:
Old Oct 17, 2002 | 05:56 PM
NJVetteGuy's Avatar
NJVetteGuy
Default Re: Best new 1/4 MPH! (C5Cemo)
Congrats :cheers:
Old Oct 17, 2002 | 10:34 PM
Chris@SD's Avatar
Chris@SD
David in Indy
Thanks ledfoot,
Scott has just a stage II heads and cam package with the regular bolt on's. He still has cats, stock rear, and stock tires. Take care of a few of these things and the times/ MPH will go even better! :smash:
I am predicting that we will see 124 MPH AT LEAST before the end of the year. :eek: :cool:
Old Oct 17, 2002 | 10:38 PM
Scott97's Avatar
Scott97
Default Re: Best new 1/4 MPH! (NJVetteGuy)
David in Indy
:reddevil :reddevil :reddevil :reddevil
I'm really pleased with the peformance.
:D
Thanks Cemo. I'm still considering the underdrive Pulley and gutting the cats or rigging up a set off pipes to swith the cats in and out. :)
Congrats :cheers:
Thanks :cheers:
Old Oct 17, 2002 | 10:43 PM
Scott97's Avatar
Scott97
Default Re: Best new 1/4 MPH! (Chris@SpeedDemon)
[b]
That would rock!
I know that I can get 122 out of it as is with a little bit colder weather.
Once the timing and fuel is tweaked, and the cats are gutted, and possibly going to a 3:90 rear I think that 124 will be a real possibility. :D
Old Oct 17, 2002 | 10:48 PM
Scott97's Avatar
Scott97
Default Re: Best new 1/4 MPH! (Superj)
Very nice Scott. I hope to break off a low 12 before the season end. :cheers:
Thanks,
A 100 shot on the gas and you'll be out of the 12's and into in the 11's. :)
Old Oct 17, 2002 | 11:56 PM
Rob K's Avatar
Rob K
Man, you are so close to breaking into the 11's. I want you to hit the 11's on those street tires. I know you can do it! Don't know where you live, but maybe some cooler weather will help you out! The weather here in Toronto, Ontario Canada is perfect for the track right now. Going this weekend, and will hopefully see a new best of my own. Don't think I can hit a 12.0 on street tire though.
Old Oct 18, 2002 | 03:03 AM
jmX's Avatar
jmX
Scott, what have you changed since you and I went to RCR together. You were trapping 118 that night right? Was it just weather? Wondering if my 115.5mph trap would be better if I tried in the good weather.
Old Oct 18, 2002 | 08:30 AM
Scott97's Avatar
Scott97
Default Re: Best new 1/4 MPH! (jmX)
Thanks for the vote of confidence! I'm really sure that I'll hit 11's on the Goodyears. In fact I'm on a mission to do so. :yesnod:
I'm betting you can get darn close if not lower than a 12.0 with a big stall.
That first '60 is the devil!
The weather has gotten cooler and that definately helps.
I'm betting that you could hit 117mph in this weather. :yesnod:
I've also spent the last couple of weeks at the track working on my shifting.
I'm trying to shift as fast as I can in order to keep the revs as high as possible. Its definately paid off.
My 60' are still in the same ballpark, I'll need some gears to get the 60' to the 1.7 mark.
[Modified by Scott97, 6:33 AM 10/18/2002]
Old Oct 18, 2002 | 10:07 AM
  #33
C5Longhorn's Avatar
C5Longhorn
Default Re: Best new 1/4 MPH! (jschindler)
Great times Scott. Congrats! :cheers:
Old Oct 18, 2002 | 10:31 AM
  #34
Scott97's Avatar
Scott97
Default Re: Best new 1/4 MPH! (rschiltz)
Thanks Rick.
I'm thinking of hitting HRP in the next couple of weeks.
Want to come and run a few?
Old Oct 18, 2002 | 11:11 AM
  #35
Fahtrim's Avatar
Fahtrim
That is awesome for street tires. Tires alone will put you in the 11's! :cheers:
Old Oct 18, 2002 | 11:16 AM
  #36
Scott97's Avatar
Scott97
Default Re: Best new 1/4 MPH! (Speide)
Thanks!
I've got a set to throw on once I hit my goal. :)
Old Oct 18, 2002 | 11:22 AM
  #37
Ram Air Tony's Avatar
Ram Air Tony
great run Scott !!!
congRATs ...... practice makes perfect my Brudda :)
thanks
To Best new 1/4 MPH!
Old Oct 18, 2002 | 11:23 AM
  #38
Steve02C5's Avatar
Steve02C5
From: Renaissance Festival TAZ the Wolfdog (R.I.P.)
C:cool::cool:L, that mph is awesome!!! :cheers:
Old Oct 18, 2002 | 11:26 AM
  #39
Steve02C5's Avatar
Steve02C5
Great driving Scott! :cheers: Quite impressive on street tires. I can see by your 1/8 MPH that you must've let off a lot because of wheel spin, that'll probably shoot up to 95/96mph when you can get some traction. Also, your trap speed is very impressive, and should be 122mph easy with some good rubber. :cheers:
Thanks Billy!
I have to baby the 1-2 shift otherwise wheelspin becomes a big issue.
I'm going to pick up a set of BFG drag radials later this month and try again.
It would be awesome to hit 122 mph all motor. :D
When you're through with the tires, I know a guy here in Houston who would like to borrow them for about 3/4 of a mile. :blueangel:
Old Oct 18, 2002 | 11:28 AM
  #40
Scott97's Avatar
Scott97
Default Re: Best new 1/4 MPH! (Steve02C5)
great run Scott !!!
thanks
Thanks RAT & Amen to that!
Thanks Steve.
I saw the HRP post and your car is kickin' major azz at the track on runflats! :eek:
Tires are definately going to drop those times. :yesnod:
I plan on heading to HRP in the next 2 - 3 weeks to try out a little of that
"sea level" air. :D
Sure would like to see/hear your car run @ full throttle. :D
[Modified by Scott97, 9:33 AM 10/18/2002]
