Best new 1/4 MPH!
Old Oct 17, 2002 | 08:44 AM
Scott97's Avatar
Scott97
Default Best new 1/4 MPH!
I went to RCR last night and managed to hit my best mph ever.
Here is the breakdown:
60' 1.9517 :rolleyes: (street tires)
330' 5.2569
1/8 et 7.91.81
1/8 mph 91.79
1000 et 10.1861
1/4 et 12.0077
1/4 mph 120.54mph
I ran half a dozen similiar #'s.
Just couldn't get hooked up from the line too well.
Oh well there is always next week. :D
My buddy Jim (jw02) ran 12.5 @ 116.xxx in his 02 Z06 as well.
Congrats Jim!
Old Oct 17, 2002 | 08:49 AM
jschindler's Avatar
jschindler
Default Re: Best new 1/4 MPH! (Scott97)
Great times Scott! :cheers:
Old Oct 17, 2002 | 09:06 AM
Scott97's Avatar
Scott97
Default Re: Best new 1/4 MPH! (jschindler)
Thanks Jim.
I need to get a set of 3:90 gears installed.
Every little bit helps. :lol:
Old Oct 17, 2002 | 09:19 AM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Not bad at all for on street tires!! Congrats!! :cheers:
Old Oct 17, 2002 | 09:40 AM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Awesome times and mph Scott, especially since being on street tires. What tires are you running and what size?
IS your beast a 97? Is it an A4? If its an A4 that is really a great MPH!
Nitrovette
[Modified by Nitrovette, 7:44 AM 10/17/2002]
Old Oct 17, 2002 | 10:20 AM
BillY2KFRC's Avatar
BillY2KFRC
Great driving Scott! :cheers: Quite impressive on street tires. I can see by your 1/8 MPH that you must've let off a lot because of wheel spin, that'll probably shoot up to 95/96mph when you can get some traction. Also, your trap speed is very impressive, and should be 122mph easy with some good rubber.
:cheers:
Old Oct 17, 2002 | 10:21 AM
Scott97's Avatar
Scott97
Default Re: Best new 1/4 MPH! (Nitrovette)
Nitrovette
Thanks Nitro!
It a 99 FRC, 6 speed, 3:42 rear running the Goodyear F1 SC tires on stock Z06 tires sizes.
Old Oct 17, 2002 | 10:25 AM
Chris@SD's Avatar
Chris@SD
Good run! Come on back and we can better your programming. You are still at only 21 degrees of timing at WOT and running rich also.
Some time soon, we need to go to the track together and do some track side tuning. :yesnod:
I will be in Austin this weekend for a wedding. I don't know how busy I am going to be with that, but maybe we could go grab a bite or head to the track.
Congrats again and congrats to Jim also. :cheers:
Scott97's Avatar
Scott97
Default Re: Best new 1/4 MPH! (BillY2KFRC)
:cheers:
Thanks Billy!
I have to baby the 1-2 shift otherwise wheelspin becomes a big issue.
I'm going to pick up a set of BFG drag radials later this month and try again.
It would be awesome to hit 122 mph all motor. :D
Old Oct 17, 2002 | 10:30 AM
C5Noir's Avatar
C5Noir
Default Re: Best new 1/4 MPH! (Chris@SpeedDemon)
Great run!
Old Oct 17, 2002 | 10:31 AM
Scott97's Avatar
Scott97
Thanks Chris. :D
The fuel definately needs to be leaned out and I think a bump to 23-24 degrees on the timing would make a noticable increase in mph and and a lower et.
I'd like to get together this Sunday if possible.
I'll be out of town Friday and Saturday.
I'll call you in a bit.
Mopar Jimmy
St. Jude Donor '06
Thanks Nitro!
It a 99 FRC, 6 speed, 3:42 rear running the Goodyear F1 SC tires on stock Z06 tires sizes.[/QUOTE]
:cheers: kEEP up the great job and impressive driving on Z06 stock tires.
Nitrovette :cheers:
Scott97's Avatar
Scott97
Default Re: Best new 1/4 MPH! (C5Noir)
Great run!
Thanks!
Old Oct 17, 2002 | 11:03 AM
oceanaire's Avatar
oceanaire
Great run!! :cheers:
I'll bet if you put some ET Streets on that monster, you'll be running mid 11's!!!! :smash:
Old Oct 17, 2002 | 11:07 AM
Mad_Dog's Avatar
Mad_Dog
Cruise-In II Veteran
Cruise-In III Veteran
Great run -- very impressive numbers. :yesnod:
Old Oct 17, 2002 | 11:09 AM
Superj's Avatar
Superj
Very nice Scott. I hope to break off a low 12 before the season end. :cheers:
Old Oct 17, 2002 | 11:10 AM
Scott97's Avatar
Scott97
Default Re: Best new 1/4 MPH! (oceanaire)
Thanks Fellas!
To Best new 1/4 MPH!
Old Oct 17, 2002 | 11:12 AM
Scott97's Avatar
Scott97
I have a set of ET Streets on "16 Centerline rims, I'm going to have 3:90 gears installed soon as well and hopefully between the two I'll get some mid-low 11's. :D
Old Oct 17, 2002 | 11:13 AM
EuG's Avatar
EuG
Good run. :cheers:
Glad to see more people try to run it on street tires – the way it’s driven on the street. :D
Old Oct 17, 2002 | 11:14 AM
Scott97's Avatar
Scott97
Default Re: Best new 1/4 MPH! (MattG)
Not bad at all. :)
Thanks Matt.
