Coolant Fill Procedure
Old Apr 24, 2018 | 10:06 AM
jeffwest5599's Avatar
jeffwest5599
Default Coolant Fill Procedure
Read a few posts on this and wanted to get opinions. I am replacing my radiator. Some of the posts say to point the nose up when draining and filling the radiator. Others say to keep level. What is the correct way. Should I point the nose upward (lift front) when draining and filling or do it all on a level surface. I understand tat lifting the front helps with air in thee system. I know final top off should be on a level surface. Thoughts are appreciated.
Old Apr 24, 2018 | 10:22 AM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
See Patches post for the GM recommended method:
https://www.corvetteforum.com/forums...tml?forum_id=1
Old Apr 27, 2018 | 06:53 AM
jeffwest5599
In the procedure above. It says that after the first cycle to remove surge cap again, idle replace then rev. This is done 3 times. My question is that after the first cycle do you remove the surge cap with engine hot or let cool down. I fear removing cap will blow antifreeze everywhere even after releasing pressure.
Old Apr 27, 2018 | 09:08 AM
Learning_Curve's Avatar
Learning_Curve
If you buy or borrow a vacuum fill tool, you wont have to worry about any air trapped in the system.
Old May 20, 2020 | 02:02 PM
corvet786c's Avatar
corvet786c
Question, Whem removing the fill cap under pressure at 210 degrees will antifreeze blow out the fill hole, Will I get burned Yikes?
Old May 21, 2020 | 08:41 AM
SledgeHammerRacing's Avatar
SledgeHammerRacing
You do not let it cool down in between heat cycles. Just open the cap very slowly to vent pressure and you'll be fine - no coolant will come flying out unless you're trying to get it off quickly. I recently replaced my water pump and followed the instructions to a "t", and on level ground, had no issues.
Old May 21, 2020 | 09:14 AM
feeder82's Avatar
feeder82
Yup remove it slowly, stop when it starts hissing dont take it all the way off till the pressure bleeds off.
To Coolant Fill Procedure
